Help! I have a electrical problem.
Old Sep 7, 2008 | 12:10 PM
John 66 Vette's Avatar
John 66 Vette
Default Help! I have a electrical problem.
Last night while drving home the problem happened 4 times. While I was drving the car on the highway everything cut off, engine, lights for about 1 second than came back on and drove fine untill it happened again. The drive lasted about 45 min. The last time it happened I was in the driveway and I hit the highbeam switch, the car died and I had to push it into the garage. I checked for power at the battery, good, starter, good, Alt, good and at the point were the wires plug into the firewall, good. No powe in the int of the car. Could there be a problem with the dimmer switch? On the drive home there were bumps in the road and it didn't do anything when I hit one of them. Thanks for your comments. John
Old Sep 7, 2008 | 12:35 PM
smokefinder's Avatar
smokefinder
I would be suspect of the firewall plug.
Old Sep 7, 2008 | 12:37 PM
Ron Miller's Avatar
Ron Miller
That'd be where I'd start . . .
Old Sep 7, 2008 | 12:47 PM
Ron Miller's Avatar
Ron Miller
(Sorry, didn't realize it had already posted.)
Old Sep 7, 2008 | 01:33 PM
John 66 Vette
I checked power to the firewall plug. Power in the engine compartment. I don't see any power at the fuse pannel. I did see the clock second hand moving, but when I opened the door it stoped. I would than check power to the alt and I would than see the clock moving, again open the door it stoped. I placed a battery charger on the car and it didn't make a difference. I'm going to pull the ingition switch and check it now. John
Old Sep 7, 2008 | 01:43 PM
67vetteal's Avatar
67vetteal
Check your Ground wire on the Bellhousing first. Al W.
Old Sep 7, 2008 | 01:55 PM
John 66 Vette
The horn blows from inside the car. Is there power going to the ing. switch at all times?
I checked the tabs on it and I didn't get anything. John
Old Sep 7, 2008 | 02:47 PM
muncieman's Avatar
muncieman
This car have a seperate small cable made into the positive bat cable like a lot of early GM cars, powers nearly everything. Could be that baby.
Old Sep 7, 2008 | 03:08 PM
Donald #31176's Avatar
Donald #31176
If youre using one of those green **** battery disconnect switches I would clean the contact area.
Old Sep 7, 2008 | 03:20 PM
ghostrider20's Avatar
ghostrider20
Headlights, interior lights, etc are powered regardless of the ignition switch. I think your problem is at the bulk head firewall plug. It could be intermittent, and or bad enough that when you load it up it heats up, and caused current drops and or fluctuations.
I would pull that, clean and inspect it. Make sure the plug pins are making contact and making a good contact. Make sure the pins are not wobbly or broken. There is a lot of current running through that bobby pin size connector.
Next, I would check and clean every ground cable and strap. Buy new screws or bolts if the old ones are rusty. If the straps are corroded buy new ones. Cleaning them removes the protective anodizing and it will be corroded again in a year or so. Clean the grounding points and use dielectric grease when you re-attach them.
Mark
Old Sep 7, 2008 | 06:52 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Others have recommended that you check the firewall plugs and I concur with this, having experienced symptoms that match yours precisely.
One thing you want to check especially well is that the locking tabs on each connector really are locked. Both connectors have two tabs and if only tab is locked, the connector can pull away sufficiently to break the connection to several circuits. (How do I know? See paragraph #1)
Good luck,
Jim
Old Sep 7, 2008 | 08:40 PM
PBChase's Avatar
PBChase
Not sure by your description when the car died did you have to restart it or not. I have a 67 small block coupe and the engine would cut out while driving. Long story short but the ignition switch had gone bad and once I replaced it everything was fine (still is too!)
Good luck.
Old Sep 8, 2008 | 04:05 PM
JohnZ's Avatar
JohnZ
It's the mating terminals for the big red wire on the inboard multiple connector on the engine compartment side of the fuse block, commonly known as the "red wire syndrome". Pull the connector off, and you'll find the terminals corroded, and the terminal cavity heat-distorted. That's why you had power in the engine compartment and no power inside the car - very common midyear problem.
Old Sep 8, 2008 | 06:19 PM
John 66 Vette
No, It started back up by it's self. Other than cuting out for about 1 second, it kept running good.
Old Sep 8, 2008 | 06:22 PM
John 66 Vette
Thanks, John I'll pull it apart and check it. Eather today or tomarrow when I get home from work.
Old Sep 8, 2008 | 07:37 PM
John 66 Vette
John, I pulled the connectors off and the terminals don't look corroded or heat distorted. There was a little bluish green on the inboard connector on the two bottom left terminals on the fuse block side. I used a small wire brush and cleaned them up. The top large red one looks good. I placed them back togather and still no power inside except horn blows and clock works but when you open the door the clock stops. Horn still works. Tomarrow I'm going to pull the battery and have it checked. With my small meter it shows 14 volts at the battery and all the ways up to the plug into the firewall. Nothing inside.
Old Sep 8, 2008 | 08:17 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
I had a very similar problem with my 65 several years back. Would run fine, then everything would shut down. Turned out the ballast resistor was shot.
To Help! I have a electrical problem.
Old Sep 9, 2008 | 01:10 PM
JohnZ's Avatar
JohnZ
OK, if you have power outside but none inside, and the terminals in the multiple connectors look good, it has to be an open circuit inside the fuse block or a bad ignition switch; if you don't see power on the 12-ga. red wire terminal on the back of the ignition switch, the open circuit is in the fuse block. Do the headlights, taillights, or brake lights work?
Old Sep 10, 2008 | 07:12 PM
John 66 Vette
John, I checked and I have power at the 12-ga wire at the ingition switch when the doors are closed and the clock works. Open the door and I lose power at the ignition switch and clock stops. I had the battey checked yesterday and the shop said it was good. I should just go and get a new battery. I checked and replaced the ground wire to the battery. After owning the car for 30 years I have never ran into a problem this frustrating. No, the headlights, taillights or brake lights don't work.
Old Sep 11, 2008 | 01:42 PM
JohnZ's Avatar
JohnZ
It's not the battery.
The clock, glove box light, courtesy lights, and brake lights are all fed by one circuit from the same fuse at the bottom of the fuse block; if the clock works, the fuse is OK, but I don't know why you lose power to the ignition switch and the clock when you open the door - that just grounds the courtesy light circuit to turn on the courtesy lights, and the fuse would blow if that circuit was shorted.
Do you have power windows?
