VIN tag question
Sep 15, 2008 | 06:18 PM
VIN tag question
What can be done to replace missing vin tag on column. Column was replaced and orig tag is gone. Good title. Legit car and deal
Sep 15, 2008 | 06:26 PM
Sep 15, 2008 | 06:54 PM
Sep 15, 2008 | 07:20 PM
You can get replacement VIN tags. Not cheap, and not exactly legal. Legal method is to get a state issued VIN tag.
Sep 15, 2008 | 08:23 PM
Quote:
Originally Posted by
emccomas
Are state tags the same size? Where are vin #s on frame? Thanks for note. Don
Sep 15, 2008 | 08:26 PM
This topic has come up before, and I believe these people were supposed to be able to do it...
http://www.datatags.com/
If I remember correctly it requires extensive proof of ownership (whatever that may entail).
Sep 16, 2008 | 06:44 AM
bigblock67
State issued VIN tags are usually the same size as the factory tag. It will NOT have the same number on in as the original VIN, in most cases.
The VIN on the frame is located on the drivers side top frame rail, about where your left hip is when sitting in the car.
