1962 electrical help
Old Sep 18, 2008 | 11:06 AM
jwm62vette's Avatar
jwm62vette
5th Gear
Default 1962 electrical help
I have a 1962 vette. My Amp Meter always reads negative. I have had the generator rebuilt, and installed a new voltage regulator. I have also installed a complete new engine wiring harness. To trace the problem, what readings should I have 1) at the generator "A" terminal, "F" terminal? I have a good voltage / Amp tester. Where should I put the + and - testers to get the readings.
What should my readings be at the voltage regulator if I test between the "Bat" connector and ground?
Which terminal should the 12 ga Red wire that runs to the Amp Meter be connected to? I have it connected to the negative (-) side.
There is a 12 ga Black wire that goes from my Pos (+) side of the meter back to the "B" terminal on the starter solenoid. The heavy guage Red #6 guage battery wire then runs to the Positive (+) side of my battery.
Old Sep 18, 2008 | 12:15 PM
JohnZ's Avatar
JohnZ
It probably reads negative because it's connected backwards - all the 1962 Corvette wiring diagrams except the one in the Assembly Manual are wrong, and show the ammeter connections backwards. The main feed from the battery cable terminal on the starter solenoid (12-ga. black wire) should be connected to the ammeter terminal closest to the driver's door, and all the feeds (red wires) should be connected to the ammeter terminal closest to the passenger side door. This error (and the correct connections) have been shown for many years in the NCRS 1953-1972 Corvette Wiring Diagram Book.
Old Sep 18, 2008 | 12:29 PM
MICK3's Avatar
MICK3
Just a suggestion: you might want to install a fusible link at the starter to protect the feed to the amp gauge if a short develops it will protect your main & ignition harnesses.
It's worth it, don't ask me how I know.
Old Sep 18, 2008 | 02:02 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Especially if you aren't having other symptoms of a discharge; battery dead, no starting, lights dim, etc.. This is a common C1 'gotcha'...
Seriously consider the prior fusible link suggestion or for slightly less protection (but entirely invisible) put a blade type fuse and holder on the back of the ammeter gauge in the wire coming from the starter. Plenty of info on this via a forum search.
Old Sep 18, 2008 | 05:56 PM
jwm62vette's Avatar
jwm62vette
5th Gear
Default 62 vette
Thanks;
I was trying to follow the wiring diagram in the 1962 Assembly Manual.
Old Sep 18, 2008 | 09:24 PM
ecorse66's Avatar
ecorse66
Have you polarized the generator?
Disconnect the Field wire from the Regulator.
Momentarily touch the Field wire to the "BAT" Terminal on the Regulator.
Just to spark, do not hold on longer than 1 - 2 seconds
Reconnect Field wire & Start Vehicle
Dave T.
Old Sep 18, 2008 | 10:41 PM
jwm62vette's Avatar
jwm62vette
5th Gear
Thanks. I am going to check the wiring per John Z's suggestion first.
Old Sep 19, 2008 | 08:56 AM
Frankie the Fink
Army
Dave T.
Actually, thats a good point since your gen was rebuilt and V/R replaced you may have done this as routine maintenance but if not you should do it now.
JohnZ said all the wiring diagrams EXCEPT the AIM were wrong, but that is what you stated you used ... if so you should be wired properly. So you COULD have a different problem - polarization perhaps.
BTW - if you get tired of screwing with that crummy mechanical V/R I have a guy that makes a solid state conversion. Its the ONLY place to get one for a generator car and its all built into the original V/R housing and undetectable.
Old Sep 19, 2008 | 09:42 AM
RoadKing96's Avatar
RoadKing96
From: Holly Springs, Nort Cackalacky / Jupiter, Florida
Frank,
What's one of those set a person back?
David
To 1962 electrical help
