WCFB Carb
We pulled the top off, check the float height (it so OK) and checked for dirt on the needle and seats but found nothing. Put it back together and had the same thing.
The guy who rebuilt the carb said it was in pretty bad shape when you took it apart and figures the seats must be shot. Anyone got any ideas? Is there any way to replace the seats?
Any help would be appreciated.
http://members.capital.net/com/studiog/CarterWCFB/.
First off, float height, position and drop on these carbs are hyper-critical. Follow the procedures to the letter...inverting the air horn, making sure the air horn gasket is NOT installed and measuring at the right position on the floats. There are DIFFERENT measuring spots depending on the carb model!! (Primary and secondary floats are different on most models - don't mix them up.)
THEN, make sure the floats are centered in the chambers...they can stick to the bowl's sidewalls if this isn't done. Make sure you don't have a leaking float - rare but it HAS happened. Some folks will tell you to set the floats some amount off from factory settings to compensate for today's gas. I don't ... I set them right on the factory spec.
Next, check your fuel pump pressure - if its over 4.5 I'd put a regulator in the circuit...too much pressure can blow the needle valves off their seats and cause the 'dribble'.
Finally, make ABSOLUTELY sure you have the right parts in the rebuild kit. My first carbs had the WRONG needle valves and these caused the plugs to foul within 20 miles of driving. Exhibited the same symptoms you are seeing and took me 3 months to find the problem....I actually think the prev owner sold me the car under appraisal because of this problem.
Mixture settings are strange on these cars. If you start with the screws out the usual 1 turn on a rebuild you are already past the optimal tuning point on some carbs. So, if you crank the screws clockwise there is no effect. In these cases, I've had to turn them counter-clockwise a bunch until the engine stumbles then run them in again until I find the 'sweet spot'...
If you get totally PO'ed at the carb and want to farm it out for a quality rebuild contact: bobkunz@att.net. He is "the man" for WCFBs !!
fdreano,
Thanks for the advice, I'll pull it apart again and try your suggestions. If that fails I'll send it off to the expert.
Thanks for the help,
Earl
One thing I would try is to remove the idle mixture screws and spray some carb cleaner followed by compressed air in the idle passages to be sure nothing in plugged. If you can visually see good air flow through there and your needle and seats are OK, something else is going on. Bob Kunz is a great choice to send the carb to. He specializes in these old WCFB's and also has the parts to fix them. I have rebuilt many of these carbs over the years and plenty of times seen the wrong or missing parts in them. The later WCFB's also use a different gasket between the main body and the base. The kits usually come with both. Either will fit, but only one is correct to line up all the passages correctly. Just a thought. I agree with Frank's comments, these carbs run great and are usually troublefree if they start as good cores and are done right.
Pilot Dan
I'll take the carb apart again this week, see what I can do and report back.
Again, thanks.
The only reason fuel could come from there is the float level is too high, fuel pressure too high as stated, needle and seat either dirty or not holding the pressure and the throttle open too much at idle allowing too much air flow through them which draws fuel out of the float bowl.
When I adjust the floats on these carbs I use a drill bit or gauge rod of the correct size.
Check timing, vac advance and ignition first.
