How Much Posi Additive?
Old Sep 30, 2008 | 02:19 PM
Too Slow '90's Avatar
Too Slow '90
Default How Much Posi Additive?
I was told that one 4oz. bottle of the posi additive was all that is required in the differential however the haynes manual says two. Anybody know which is correct?
Thanks,
Roy
Old Sep 30, 2008 | 02:26 PM
ren's Avatar
ren
I had two bottles added about three month ago.
Old Sep 30, 2008 | 02:40 PM
Too Slow '90
Thanks...that's the info I needed.
Roy
Old Sep 30, 2008 | 03:00 PM
Trophy Blue's Avatar
Trophy Blue
I added 8ozs. to mine about two months ago.
Old Sep 30, 2008 | 03:02 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i used 2 bottles in mine
Bill
Old Sep 30, 2008 | 07:03 PM
vettn's Avatar
vettn
Two bottles for a complete fluid change to start and if the clutches still grab, put another in. I have had to do that before.
Old Sep 30, 2008 | 07:15 PM
Chambered's Avatar
Chambered
Do you need ANY additive if you are running pure synthetic lube? I've heard you don't need the additive.
Old Sep 30, 2008 | 09:20 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
some people say 'yes', some 'no'.... better to add it and be safe....
Bill
Old Sep 30, 2008 | 09:21 PM
mikem350's Avatar
mikem350
Good question, some of the bottles say "no special additive required"
Old Sep 30, 2008 | 09:35 PM
toddalin's Avatar
toddalin
I usually use about a tube. I prefer the KY Brand.
... Oh wait..., what was that???
OOOOOHHHHHHH he said posi fluid.
That's very different. Never mind.
Old Oct 1, 2008 | 08:41 AM
GTR1999's Avatar
GTR1999
If the posi is hammering around corners use 2, if not and you're just doing a PM then use Lucas 85-140 gear oil and 1 bottle-only use GM additive. If you still have hammering then you can either drive it or drop the diff and build the posi to stop hammering.Many know how I do this.
Good luck.
To How Much Posi Additive?
