Harmonic balancer - timing mark
Old Oct 7, 2008 | 05:40 PM
TJefferson2020's Avatar
TJefferson2020
Default Harmonic balancer - timing mark
I just picked up a new balancer - I noticed that the timing mark on the old balancer was in a different spot (in relation to the keyway) than the new one - but I'm pretty sure the outer ring had moved on the old one.
I bought the correct balancer for my motor (1970 LT1) from Zip - is it safe to assume that the timing mark on the new balancer is in the right place or do I need to get a piston stop and confirm TDC?
I would think that's a pretty critical issue for a new/replacement balancer.
Hoping to re-install the freshly rebuilt motor this weekend. All new roller valve train!
Old Oct 7, 2008 | 05:53 PM
Powershift's Avatar
Powershift
I would not take any chances, and would use a TDC finder tool to confirm TDC. It's to important to leave to chance. Since the motor is out of the car, it should be even easier to do.
Larry
Old Oct 7, 2008 | 07:15 PM
Plasticman's Avatar
Plasticman
As posted previously by JohnZ:
The timing index line on the balancer (and the corresponding "0" mark on the welded timing tab) were moved 8 degrees counter-clockwise on long-water pump passenger car applications starting in 1969 (Corvette didn't change until several years later); if you have a "finned" balancer, it's previous to that change, and should have the index line directly aligned radially with the key slot in the hub, and the correct corresponding timing cover has the timing tab welded on. All the bolt-on timing tabs I'm familiar with are for post-1969 applications.
JohnZ is offline Report Post
Old Oct 8, 2008 | 12:52 AM
buns's Avatar
buns
If you find this to be true...PLEASE...snap a pic. I have worked on some crusty 55 year old motors where the rubber in the balancer is cracked and bulging out, and am always amazed that TDC is where it should be. In the meantime, I have put together this montage for your viewing pleasure.
Old Oct 8, 2008 | 08:24 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
This is correct.
The timing mark changed (except Vettes) from 1968 to 1969 on MOST Chevy products. I don't know what year the Vette balancers changed (about 71-72?), But you DO NEED to have the correct corrosponding balancer/timing cover tab matched to each other.
Old Oct 8, 2008 | 10:26 AM
TJefferson2020
Hmmmmm... my balancer is finned. But the application is 1970 - I'll call Zip to confirm the correct balancer.
I'll take some pics later today and post. I agree - checking TDC is a good idea.
Old Oct 8, 2008 | 01:03 PM
67L36Driver's Avatar
67L36Driver
Tom:
Do small block dampers have witness marks? I don't have a small block damper handy but my spare bb has a diamond shape dimple on the hub and a round dimple on the outer ring.
Marks are about 165-170 deg from the tdc mark on the face.
Old Oct 8, 2008 | 01:15 PM
Plasticman's Avatar
Plasticman
Originally Posted by 67L36Driver
Tom:
Have not seen any, and the SBC 8" I just looked at does not have any.
However, would not be a bad idea to add a couple of alignment punch marks when new (for checking down the road).
Plasticman
Old Oct 8, 2008 | 01:54 PM
RoadKing96's Avatar
RoadKing96
From: Holly Springs, Nort Cackalacky / Jupiter, Florida
So I have a finned balancer and it seems to be off just a couple degrees from the key way, when putting a straight edge to it.
The rubber and all appears to be good.
So how does one go about correcting? (If possible at all)
Thanks,
RK
Old Oct 9, 2008 | 01:57 AM
67L36Driver
Originally Posted by RoadKing96
So I have a finned balancer and A: it seems to be off just a couple degrees from the key way, when putting a straight edge to it.
B: So how does one go about correcting? (If possible at all)
Thanks,
RK
A: That's the way it is supposed to be
B: You cannot.
Old Oct 9, 2008 | 07:49 AM
DZAUTO's Avatar
DZAUTO
Tom:
I've never seen them from the factory, BUT, I have known of people punching the hub/ring on new or used balancers that are known to be be correctly indexed.
Even if a balancer ring is suspect, it wouldn't hurt to punch the ring/hub so that after several miles it could be checked to see if the ring has moved---------------ESPECIALLY WITH AN ENGINE THAT WILL RECEIVE SOME PUNISHMENT!
To Harmonic balancer - timing mark
