Pilot Bushing?
Old Oct 16, 2008 | 06:18 PM
Mikey65's Avatar
Mikey65
Default Pilot Bushing?
Which pilot bushing do I need to use with my new engine? I did a search and found a plethera of threads, but noting definate as to what I need to use. I thought there would be a centerforce kit that came with all of this, but I guess not..
Old Oct 16, 2008 | 06:41 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
I used bronze, maybe that makes me old fashioned... which would be correct.
Old Oct 16, 2008 | 07:31 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Having used both oilite bronze and needle bearing bushings in the past, i used a GM bronze oilite bushing on my latest motor.
Doug
Old Oct 16, 2008 | 08:26 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Smeding didn't put one in? For all that money?
Old Oct 16, 2008 | 09:33 PM
Mikey65's Avatar
Mikey65
You know I didn't look.. they don't mount the flywheel, but it might be with other parts on the intake. I actually got to thinking about it while looking at clutches.. but no there is not one installed...
Old Oct 16, 2008 | 10:05 PM
claysmoker's Avatar
claysmoker
I think I would be over there asking for one.
Old Oct 17, 2008 | 03:35 PM
JohnZ's Avatar
JohnZ
When you buy a pilot bushing, take a magnet with you - if the bushing is magnetic, keep looking. GM #10125896, Federal-Mogul #PB-656-HD, and NAPA #BK-6151161 are known to be made of the correct Oilite bronze.
Old Oct 17, 2008 | 06:32 PM
chris ritchie's Avatar
chris ritchie
Check them with a magnet. I recently found the Federal Mogul and the NAPA ones to be slightly magnetic. Only the Chevy one wasn't.
Old Oct 24, 2008 | 10:51 PM
Mikey65's Avatar
Mikey65
Picked this up from the GM dealer today.. part#10125896. This look correct? I assume the beveled side goes towards the engine? I was going to put it in the freezer overnight... any other tips to installing this thing?
Old Oct 25, 2008 | 01:16 AM
Mikey65's Avatar
Mikey65
I read t not use grease... use a light coating of oil to ease it in? If it doesn't ease in, what are some methods for assisting it in?
Old Oct 25, 2008 | 07:31 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Beveled side of hole goes toward the trans to aid install!
Old Oct 25, 2008 | 07:46 AM
Plasticman's Avatar
Plasticman
If it is a true porous bronze bushing, do not grease the inside bore or the trans input shaft that slides into the bushing bore. You can add a light film of motor oil at time of trans installation onto the trans input shaft (where the shaft rides in the pilot bushing).
You could use a light coating of grease if you wish to help ease the pilot bushing in to the end of the crankshaft. Just do not put any grease in or around the bore of the bushing.
You can also put it in the freezer overnight to "contract" it. However, I have never needed to do this. But then again, I have always used OEM cranks, so the crankshaft bushing bores were pretty much "on the money".
Plasticman
Old Oct 25, 2008 | 10:16 AM
Mikey65's Avatar
Mikey65
Um... there is a beveled side and a curved side.. the beveled side with the sharper edges goes towards the tranny??? Not the curved side?
Old Oct 25, 2008 | 10:45 AM
Shurshot's Avatar
Shurshot
What about when other than stock transmissions are used?....... plus I have a non stock crank
I used a steel bushing from Keisler but I have not done enough driving on it to draw any conclusions one way or the other.
Doug
Old Oct 25, 2008 | 11:01 AM
CJS's Avatar
CJS
Beveled side toward engine, curved side toward transmission.
To Pilot Bushing?
