Running lean ??
Old Oct 18, 2008 | 07:18 PM
Kurt G.'s Avatar
Kurt G.
Default Running lean ??
65' vert 327/365, fresh motor,trans,distributor, Holley carb....seems to be running a bit lean- QUESTION: When trying to adjust the "lean-ness" (couldn't think of another term at the moment), which way do I turn the large brass screws on either side of the front bowl of the carb? clockwise or counter clockwise?? Thanks for any replies....
Old Oct 18, 2008 | 08:03 PM
Bill Irwin's Avatar
Bill Irwin
Kurt, You would turn them clockwise. But, someone may have changed the jets inside the carb. Bill.
Old Oct 18, 2008 | 10:44 PM
Kurt G.'s Avatar
Kurt G.
"Clockwise" for leaner?
Old Oct 18, 2008 | 10:49 PM
GCD1962's Avatar
GCD1962
Counter clockwise to make it richer. Clockwise to lean it out.
Old Oct 18, 2008 | 10:58 PM
Bill Irwin's Avatar
Bill Irwin
Kurt, I reread your post, my error, CCW to add more fuel/air mixture. Sorry, Bill. But the thought re: jet change still applies.
Old Oct 19, 2008 | 07:38 AM
DansYellow66's Avatar
DansYellow66
This is only going to adjust the static idle mixture - is that all your interested in doing?
Old Oct 19, 2008 | 08:09 AM
MikeM's Avatar
MikeM
The "large" screws are the bowl plugs. The "small" screws are the idle jets.
What are you trying to fix?
Old Oct 20, 2008 | 01:22 AM
Kurt G.'s Avatar
Kurt G.
Recently had distributor/timing dialed in...carb is completely rebuilt and set for the rebuilt motor. When I started the car cold the other day and tried to drive it onto ramps (not warmed up yet) it backfired 2 times thru the carb. Thought that might be a sign of running a little lean........
Old Oct 20, 2008 | 05:39 AM
MikeM's Avatar
MikeM
I wouldn't try to adjust anything on a cold engine. Choke working?
Old Oct 20, 2008 | 10:03 AM
Jims66's Avatar
Jims66
Make sure you stick a new power valve in it since you backfired a couple of times.
Old Oct 20, 2008 | 10:31 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
One other thought is that the accelerator pump discharge may not be set correctly. The engine will lean out when you step on the accelerator and will backfire until it catches up when the added fuel gets to the cylinders.
Just a thought.
Steve
Old Oct 20, 2008 | 02:12 PM
Kurt G.'s Avatar
Kurt G.
Where is the accellerator pump adjustment??
Old Oct 20, 2008 | 02:23 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
Is there a way to check the power valve? If one was bad, would the car still run fine but idle rich?
Old Oct 21, 2008 | 08:26 AM
J.K. Cooley's Avatar
J.K. Cooley
If the power valve is bad, the carb will be dumping fuel, smoking(exhaust), and won't idle .....
The mixture screws only affect the mixture while the carb is in the idle curcuit ( car idling )........
The plugs should be a light brown when you have your tune up right...[ plugs will be a white color indicating a lean condition].....
To Running lean ??
