rear spring install ???
Old Oct 22, 2008 | 10:45 PM
LT1driver's Avatar
LT1driver
Default rear spring install ???
installing rear spring on 67, do you snug bolts up and then lower car and with weight of car on springs do final torque or do you just torque bolts while wheels off ground?? thanks.
Old Oct 22, 2008 | 10:57 PM
DansYellow66's Avatar
DansYellow66
Wait to tighten the bolts that secure the spring to the differential cover, until after the weight is on the wheels.
Old Oct 22, 2008 | 11:03 PM
66jack's Avatar
66jack
What if a person tightened them and drove the car first??
Can a you go back and fix it?
Will it screw up your alignment?
jack
Old Oct 23, 2008 | 03:15 PM
LB66383's Avatar
LB66383
Go back and fix it? Not sure what you mean there. The reasons for torquing the bolts after the weight is on the spring is to have the spring as flat as possible. With the car in the air, the spring is arched so you don't get an accurate torque reading, and there is a possibility of cracking the carrier. Check the torque with the car on the ground and make sure it is correct. The spring does not affect the alignment.
Old Oct 23, 2008 | 03:46 PM
64Corvette's Avatar
64Corvette
You can set the rear wheels down on some steel rims and still have enough room to torque the 4 bolts that hold the spring on!
Old Oct 23, 2008 | 03:56 PM
DansYellow66
jack
If it didn't crack the carrier then it's OK. I did it backwards many years ago before I knew better.
Old Oct 23, 2008 | 11:23 PM
LT1driver's Avatar
LT1driver
thanks guys
To rear spring install ???
