C1 dual master cylinder
#101
Having no machining skills, I bought the C1 modified Mopar master cylinder from Vette Products of Michigan. On my 59, I have a rebuilt 383 small block with a 4900R Fuel Injection unit rebuilt by Jerry Bramlett. Jerry made it a work of art. I also have the Jim Meyer IFS. I'm installing vintage air and painted the compressor black to blend it in the compartment better, and also added the Powergen alternator. I will probably add a Frigidaire sticker to the compressor and a dated delco generator tag to the alternator to go along with my "Foolie" theme.
I was able to install the master cylinder without drilling out and flipping around the bolts from the brake/clutch bracket. It took quite a bit of sequencing/fiddling around to get it done. I got lucky and ended up with a little bit of space between both the M/C and the air cleaner, and the air cleaner and the alternator. Here are some pictures of my current progress:
#103
Thanks! There is a little more clearance than what it shows on that picture because the m/c is higher than the slope of the air cleaner. Plus, I don't have the lower mounting bolts for the a/c mounted for that mock up; when I do, I can rotate the a/c counterclockwise and get another 1/8" of clearance. This gives me about 3/8" of clearance which is hopefully enough without having to shave any off the m/c tip.
#104
Plasticman
#106
One more thing, I used the stock firewall seal at the firewall instead of the nicer metal spacer Charles fabricated (see post 30). The m/c is on tight and does not rock any when I push on it, so I think it will work. It is Corvette Central part no. 191009:
http://www.parts123.com/corvettecent...50e&ukey=43817
#107
The brass seats in the fitting holes are flare seats and are replaceable if they become deformed, they are also used on some power steering units that use direct flare lines. They are easy to replace, some years ago I bought an assortment of sizes and keep them in a small box and still use one every now and then to stop a leak.
Bill
Bill
#108
Received 2,130 Likes
2015 C2 of the Year Finalist
It is designed for 4 wheel drums because the reservoir does not hold the quantity of fluid considered safe for disks as they wear. The piston and travel will work with disks but because disks require more fluid as they wear than drums a master designed for disks holds more fluid.
As such you MUST CHECK fluid more often when using this master with disks in the front. ALSO! This master has residual valves in BOTH ports because it is intended for drum brakes. You MUST remove the residual valve from the port for the front brakes before using it with disks.
Dan
#109
Dan,
Nope, not all of them had the residual pressure valves (mine was a new Cardone unit without the valves in either port).
See post #92 for all of various the part numbers.
And yes, if they had the residual pressure valves, in both ports, the bowl that serves the front disk calipers should have the valve removed.
Yes, this is an old thread, but think inaccurate post info should be corrected, before it is closed..
Plasticman
Plasticman
#110
Dan,
Plasticman
Plasticman
Dan
#111
Dan,
I never stated that it came for a 4 wheel drum system. Nor did I state that it ever came from a Corvette supplier (it did not, it was purchased by fellow forum member WMF62 from a local auto parts store). I was the one who modified two of these M/C for use in our two 62 Corvettes, using the concept trail blazed by fellow forum member Cbernhardt.
Some Mopars of that era came with disk brakes. I have used Mopar 4 piston calipers in the past from this time frame, so I have to think this application was used for one of them. My old Kelsey-Hayes parts catalog show Mopar disc brakes for cars as early as 1965, but I do not have a cross reference for what M/C came with what brake system. I suppose I can look in my old Hollander later.
I am simply stating that not all came for dedicated drum systems, and this aftermarket supplied M/C did not have the residual pressure valves in either port.
Just wanted to make sure that forum members may be looking for a residual pressure valve, where it may not be present.
Plasticman
Plasticman
#112
Dan,
Plasticman
Plasticman
I own many vintage Chrysler products using drum and disc brakes that Master and others as well. Don't want to see anybody get hurt.
Dan
#113
...I should add that if you ask for a Chrysler, Dodge, Plymouth master for a 67-70 application, drum/drum this is the master you will get. All of them are Chinese made reproduction of the original center bolt Mopar unit and all of them will have residual valves in both ports. What you have sounds like something modified and repackaged.
Dan
Dan
#114
Dan,
Plasticman
Plasticman
