Am I correct?
Old Oct 24, 2008 | 04:40 PM
Gman58's Avatar
Gman58
Default Am I correct?
These are the numbers on my block. I used on line resources to verify everyhing. I am no expert but it may have been a Chevelle motor?
Thanks Greg
T083IEE = Tonawanda Aug 31 New York 327 4 barrel Auto
H227 = Aug 22 1967
3914660 = 327 275hp L30 car
Old Oct 24, 2008 | 08:03 PM
Gman58's Avatar
Gman58
Hmmmmm?
Old Oct 24, 2008 | 08:21 PM
muncieman's Avatar
muncieman
Thanks Greg
H227 = Aug 22 1967
3914660 is a 68 327, 2 bolt main block. I had a 68 327 three speed car, very strange option, but I never paid much attention to the block, just drove the wheels of the thing
I found some more data;
3914660 327 68-69 Pass,Chevelle,Camro, Nova,Truck
3914678 327 68 Corvette 300,350 HP lrg journal 2 bolt main
Old Oct 24, 2008 | 10:48 PM
Gman58's Avatar
Gman58
Default Ok
Thanks for the input. This motor is working very well for me. Pleanty of juice. Thanks Greg
Old Oct 25, 2008 | 12:03 PM
Mike Ward's Avatar
Mike Ward
The EE code used for a '68 model year car narrows it down to only one choice:
327 cu in. Powerglide 275hp 4bbl A or X body
Old Oct 25, 2008 | 08:14 PM
Gman58's Avatar
Gman58
Default Ok
Thanks for the additional info Mike. Greg
Old Oct 31, 2008 | 12:25 PM
ardalan's Avatar
ardalan
Default timing.
I have the same block in my 61, have q-jet rochester carb, and having problems with overheating, I suspect its a timing and/or running too lean issue and was wondering whats the optimal timing for that blcok any help is much appreciated. cheers
Old Oct 31, 2008 | 12:40 PM
Gman58's Avatar
Gman58
Default Overheating
I will check my records for you. I am running electronic ignition with a new carb. I am running a 180 thermostat and stock radiator. I have never had a problem with overheating. Prior to the ignition and carb change I was running a dual point with a Quadrajet carb. This configuration also ran normal as far as temp was concerned. Probably not much help but I wanted to respond anyway. Greg
To Am I correct?
