'60 windshield post spacer thickness?
Old Nov 10, 2008 | 09:40 AM
mn.roadking's Avatar
mn.roadking
Default '60 windshield post spacer thickness?
Removed windshield assy this weekend to replace dash pad. Spacers missing between windshield posts and body. Anyone know thickness and material?
Old Nov 10, 2008 | 05:07 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
If you mean these:
http://www.parts123.com/parts123/yb....Z5Z5Z50000050x
You are best off just ordering this package -- some cars only need 1 on each side, most need two and some, like mine, need 3. This package is cheap, has the correctly shaped parts and includes enough pieces to shim things properly. Do NOT use any sealant in between layers of these rubber items...it will squeeze out and make them slide around and come out of their correct position.
Old Nov 11, 2008 | 08:43 AM
mn.roadking
Hey thanks! I couldn't find those in their catalog to save my life.
Old Nov 11, 2008 | 09:42 AM
Frankie the Fink
Army
No problem. I put some 'strip caulk' in between two of these shims when mounting my windshield and when I tightened the T-bolts it oozed out everywhere and made a big mess. You don't need ANYTHING in between these rubber pieces...
To '60 windshield post spacer thickness?
