installing offset trailing arms - help needed
I'm installing a set of Vansteel offset trailing arms and have hit a few snags. First, I'm having problems attaching the e-brake cable. The position/angle of the cable bracket seems incorrect; the angle at which the cable housing attaches to the trailing arm does not align with the direction of the cable as it exits to connect to the e-brake. Additionally, routing the cable housing inside the TA appears as if it will interfere with the flexible brake hose and I can't see that routing the cable outside the TA will work either. Does anyone have experience with installing, routing, and attaching the e-brake with these arms?
Lastly, the TAs are interfering with the frame on the inboard side where the TAs exit the frame. I have not yet installed the shims or tightened the pivot bolts, but everything else is attached (shocks, half shafts, leaf spring, etc.). It looks like it will interfere with the frame even more if I were to put the car back on the ground.
Any suggestions or assistance would be greatly appreciated.
Dave B
Carpinteria, CA
'65 coupe
Harry
Sorry I do not remember his username but I believe it had "race" in it.
Doug
Anyway, my frame was slightly modified in order to fit the TA. It appears, just like you are seeing, there was an "inside" fit issue. Therefore, they modified the frame. Here are some pics.
Driver's side:
Passenger side
This is the next project I have hopes for but I will need a better fit than having to go to that extreme
I do believe there are quite a few midyears with offset TA's that have more or less been a bolt on minus the parking brake issue.
Doug
I did contact Dan at VanSteel. He has been quite helpful. Here's what I've learned so far:
The e-brake requires a significant bend to the cable jacket. It is best to attach the jacket to the TA first then bend it in a tight "S" shape to align with the bracket on the frame. My concern about the angle of the bracket has been noted. He did not comment much on that but acknowledged that the cable does exit from the jacket at a significant angle as it routes to the e-brake. He assures me that it works. I'm an engineer and, as such, continue to be skeptical. I'll hook it up as he suggests and see what happens. Experience is much better than knowledge. He also indicates that even with the cable jacket and flexible hose routed behind the TA, he's never known of abrasion of the hose by the cable jacket.
As for the TA to frame interference, Dan assures me that with the shims in place, there should be adequate clearance. We shall see... He did send me an instruction sheet as well.
I have not yet had time to implement what he's suggested but, over the weekend, I hope to have resolved these issues and be back on the road soon.
That's all for now,
Dave B
Carpinteria, CA
'65 coupe
I got the e-brake cables attached and working. The right side was a bit of a challenge but went together OK. The left side was even more challenging; the cable jacket still slightly inteferes with the brake hose. I ended up tweaking the brackets on the frame and on the TAs a bit to improve the alignment of the cable and its routing, also to help keep it away from the hoses. I plan to shake it down for a few miles and check it again. If the interference continues, I'll give it another try... or add a protective sleeve over the hoses or maybe switch to braided hoses.
The TAs went together OK once I followed the instructions supplied by Dan at VanSteel. I installed the shims to roughly set the caster and for now it seems to track OK, at least well enough to get to the alignment shop.
So with all said and done on this latest project, I installed a VBP composite spring and KYB shocks, an Eaton posi using my original 3.36 r&p, VanSteel offset trailing arms, adjustable strut rods, new metal brake lines, brake hoses, a set of grease-able u-joints, as well as some worn out items I had not planned on: an e-brake cable, new rear rotors, new spindles, a new transmission slip yoke, and a few other bits and pieces not listed.
The most important thing I discovered was during the installation of the composite spring. The mounting bolts supplied by the spring manufacturer were too long!!! They bottomed out in the threaded holes when I screwed them in. There was up to 1/4" of thread remaining before the bolts fully seated and engaged the lockwashers. Had I tightened them completely or used a power driver, the screws could have pushed right through the pumpkin.
All the hard stuff is now done! And the car's ride is awesome! Alignment is scheduled for Wednesday, then the fun begins!
WOO-HOO!
Thanks again for all the feedback and information
Cheers,
Dave B
Carpinteria, CA
'65 coupe
This pix is a wheel size of 17X9.5 with a 5.5 backspace. The size is 275/40/17. I used this wheel and tire off my son's chevelle for fitment purposes, and it's slightly too large for my vette.
I'm planning to go with a 17X9 wheel with a 5.5 backspace and a 255/45/17 tire. I want some meat on my tires.
The wheels should be here in a couple weeks.
What wheel style are you going with? Your sizes sound about right.
My plan right now is to go with the cobra style wheels like the one you see in my pix. I'll probably order my wheels and then go to a local tire shop and have them fit the tires.
I've also been going back and forth for a couple of years. Most of what you see on mid-years are TT's and I want something different.
I'm 99% on these wheels, and hope to order within the next couple weeks.
Dave B
