Front Body sagging
To lower the hinges and remove the hood rattle of worn out hinge spring washers:
1 Obtain a small round file, (2) 0.25 diameter bolts, and (2) nylok nuts, (4) plastic flanged bushings used in c2 accelerator linkage between linkage rod and rubber grommet. The bushings have a 0.25inch inside diameter.
2 drill out the hinge pins with a drill the same diameter as the pin.
3 Use a small round file to enlarge the holes to accept plastic bushings while lowering the hole center in the bottom half of the hinge and raising the hole center in the top half of the hinge.
4 Install plastic bushings in both halves so the bushing flanges are against each other, trapped between the hinge halves.
5 Install the bolts through the bushings with the nylok nuts on the outside of the hinges and tighten just enough to remove all end play.
PS if that lowers the hood too much, put sheet metal shims (aluminum sheet/flashing) under the hinges.
