ZZ4 Headers
Old Nov 21, 2008 | 05:16 PM
markiemyster's Avatar
markiemyster
St. Jude Donor '03 & '05
Default ZZ4 Headers
I'm thinking of purchasing a ZZ4 and a Tremec TKO ???.
Does anyone sell a set of headers that would be similiar to the ram horm exhaust manifold that are on my engine now. I was hoping that I wouldn't have to change my existing under car 2 1/2" exhaust if I didn't have to.
Also with a ZZ4 (355HP / 405 ftlbs of torque) and a 3:55 rear end I was trying to decide which TKO to purchase. Does anybody have this setup. Most of my driving is in the 40MPH range but I would like to cruise the highway at 70 comfortably also.
Thanks, Mark
Old Nov 21, 2008 | 05:50 PM
Muttley's Avatar
Muttley
I think your rams horns should bolt up OK to the ZZ4 heads if you want to use those. There is apparently a port mismatch because of the ZZ4's larger D-shaped ports, but several members have reported that you can take a die grinder to the manifolds and match them reasonably well.
BlueShark29's Avatar
BlueShark29
I installed a ZZ4 in my '65 coupe a few years ago. The stock ramshorns bolted up to the aluminum heads and to my original sidepipes. Being a 350 hp car, it had 2 1/2" exhaust on it.
If you want a header, I understand that McJacks has a tubular exhaust that is a direct replacement for the ramshorns. I have not tried them, just heard that they work.
Old Nov 21, 2008 | 07:43 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
I installed ZZ4 - TKO500 last winter and couldn't be happier I'm running 3:08 gears so the VERY low 1st gear that the TKO500 has is ideal. I use the ram horn exhaust just die ground them a little. They bolt right up but I used some copper gaskets.
Here is a bunch of pic I took ===>> Click Here
I have lots more pic if you need to see something
George
Old Nov 21, 2008 | 08:39 PM
63 340HP's Avatar
63 340HP
If you want to keep your original manifolds for a future restoration (avoid grinding on the originals) Brzezinski has CNC ported ramshorn manifolds that offer a port entry larger than the ZZ4 port.
Ported Corvette manifolds
These are the china castings, with the 2.5 inch outlets. Most left & right bracket versions are available. The CNC porting opens the inlets to a 1404 gasket (larger than the ZZ4 head, and good for a flow reversion step).
The owner, Randy, will remove the heat riser tube and plug the holes with set screws, or have the tube fitted for the stock carb/choke setup. Let him know what you want. The price is about what a set of quality headers will cost, but they will bolt up to the stock exhaust.
With a little extra hand porting to open up the collector and outlet they will flow very well. I just wish I had the cutting tools to reach in deep enough to remove the bracket & bolt hole casting bosses that protrude into the #1 & #3 inlet ports ( if anyone offers guidance).
Old Nov 21, 2008 | 11:01 PM
hogan64's Avatar
hogan64
These are D Port McJacks Headers on a ZZ383. They replace rams horns exactly.
Ted
Old Nov 22, 2008 | 05:02 AM
markiemyster
Thanks guys that's the info I was hoping for.
To ZZ4 Headers
