Cleaning Hooker Sidepipes (Chrome)
I am ready to re-install my Hooker chrome headers and sidepipes on my 63.
I would like to clean them before installation. There is some blue-ing on the chrome - is there anything I can use to get rid of that? Also, there are a few spots where oil dripped onto the pipe and burned - any suggestions for cleaning that?
Thanks in advance for any suggestions.
kbuhagair, why are your sidepipes blued anyway???
i have been running hooker header/sidepipes since the 70s on a highly modded engine and the only blueing/browning/discoloration i have experienced is within 6 inches of the heads. my sidepipes never had any blueing, they just developed rust pitting.
i.m restoring my 64 and just pulled the trigger for new chrome side pipes from summit ($330) they are just the chrome pipes, the trick is getting the baffles out of the old pipes...
i have been running hooker header/sidepipes since the 70s on a highly modded engine and the only blueing/browning/discoloration i have experienced is within 6 inches of the heads. my sidepipes never had any blueing, they just developed rust pitting. thumbs:
The bluing I have is similar to what you describe.
A bit of history is in order here; I purchased my car in 1984 and drove it for about 1 year / 3000 miles. It has been off the road, albeit in secure dry storage, since then.
The current condition of the headers & sidepipes are pretty much the same as when I bought the car. Besides the bluing, there is black crud covering the header pipes on both the passenger and driver side (which I'm assuming was caused by engine oil leaks).Surprisingly, the outside portions of the headers which hang off of the sides of the car, and the sidepipes themselves, are in remarkably good condition (see avatar). The chrome is still perfect with a great shine. Only the underhood portions of the headers need some serious chrome lovin'!
Being as how these pipes are over a quarter of a century old, and considering the price of new Hookers
, I guess should be thankful they're still in one piece...!
Since you mentioned both the headers AND the sidepipes, I'm assuming the "bluing" is actually on the underhood headers (I think that's what you reiterated). That is how mine are too, and I believe there's not much one can do about that while they're still on the car, short of spraying "chrome" spray to change how it looks. The dealer did that to a portion of my headers at the collectors and it did not look that good, so I steel wooled it off back to the oxidized finish. I've been told that I can re-chrome if there are no rust holes, and I may just do that if I get an exhaust leak sometime. I don't want to take things apart just for that at this time. Since yours are off, this may be the easiest opportunity to get it done. Good luck.
Carlos
PS Your two hole clutch rod rubber boot is still holding up on my car
I see it's sold on Ebay
http://tinyurl.com/6p8oee
Came from UK originally I believe.
I have been told the heat from breaking in a new/rebuilt engine or if your carb is too lean it will blue the pipes.
Might want to check your A/F ratio.
Good Luck.
Larry
Autosol is at the top of my list of abrasive Ghrome polishes, It'll take the blue off alright..........
