APPROXIMATELY 1959 model 283s, and all subsequent SB heads thereafter used three lengths of head bolts, with the two end bolts being the middle length.
That's what I meant - should have been more specific about years.
all 265 and early 283 engines had two length's . there was a head change and it could have happened when they went away with staggered valve cover bolts , anyway the two intermediate head bolts were used later and at the end of each head....sounds like you have an early 283 ..
Originally Posted by bigblock67
Why do most small block head bolt kits come with 3 length bolts when the 2 middle length bolts provided will not work on my 283s. All bolts under cover are same length. Need explanation.
Don
John, Good try looking. Amazing isnt it. Corvette central knows about this. Went thru same problem until they listened to what the facts were. They stated that a new part# will be created . Your pic was a little blurry. I couldnt make it out. Thanks for your effort.
Don
Why would you not accept the Chevrolet catalog from 1957 pictured in post 18?
I DO accept the Chevrolet catalog. The point that I was trying to make was that the manufacturers and vendors and a whole lot of old small block chevy owners are not aware of this.
Don
The last line in the catalog, post 18 reads:
57 ALL,CORV. (8 cyl) long (7/16-14x3 3/4)(raised circle on top of head)
3741278 18 .15
The key is 18 long bolts vs 14 for later heads. There were no intermediate (3") bolt listed since they were not used at that time.
By the way, what are your favorite Doors songs. Have you listened to their uncut version of Gloria on you tube?
Good luck
