54 timing mark?
Old Dec 2, 2008 | 09:11 PM
MasterDave's Avatar
MasterDave
Moderator
Default 54 timing mark?
Anyone got a pic of what the heck the mark looks like? I surmise it's on the flywheel because I see a pointer on the trans housing hole but I don't know what it looks like. Using the thumb over #1 compression method I find what looks like a small raised dot....just not sure. Thanks
Old Dec 2, 2008 | 09:13 PM
GCD1962's Avatar
GCD1962
Not sure on a '54, but on a '40, it's a ball bearing welded to the flywheel
Old Dec 3, 2008 | 12:58 AM
TroyPyles's Avatar
TroyPyles
Yep. Its the same deal Dave. A small ball bearing embeded in the flexplate. Paint it white for ease of reference. On my 54 lining up the pointer with the ball bearing does not indicate exactly TDC. I understand when they are aligned the points should just be breaking open. So this would be as some specified degrees before or after TDC.
Old Dec 3, 2008 | 10:26 AM
MasterDave's Avatar
MasterDave
Moderator
Thanks, I'm on it. Troy, we need to get together.
To 54 timing mark?
