350 small block expert needed
i want to put new aluminum heads and a little bit bigger cam in it.
i was thinking of going with trick flow heads and a trick flow hydraulic
roller cam.
what do most members think of trick flow heads?? are they any good?
i noticed that AFR heads seem to be pretty expensive compared to
trick flow?? why is this??
i am trying to make around 500 HP and about 450 torque?
my present cam is a hydraulic roller comp cam. it is a pretty good
cam but no enough rumpity rump for me?? i want a little bit more
cam but not something too radical for the street. any help or
suggestions would be greatly appreciated. thanks
Dave
By the way, they got comparable peak results with both flat tappet and roller cams, although the roller worked better at lower rpm. So I'd think, if you have the cash, roller is the way to go.
Harry
Harry
I thought a ZZ4 was a 383 or do they make more than one???
Shows you what I know, 350 is the base motor with vortec heads.
I've been looking into the Edelbrock top-end packages - heads, cam, gaskets, and intake matched set. I have a Mckinnon cast early 70's 350 block. I think its the one with the high nickel content. So I may keep it and just refresh the top-end vs. buying a crate short block...
I'd be interested in hearing anyone with input on the Edelbrock kits.
here is a primmer about what i know of engines:
there is no free lunch, what you gain in horsepower you will lose in torque.
max. horsepower is developed at high RPMs, torque is developed in the mid-range. you can look at numerous builds that will say:
max torque 400 FT/LBs at 3500 RPMs, max HP 420 at 6200 RPMs (or whatever numbers you want plug in).
now if you are driving your car around on the street are you more likely to be driving around 3500 RPMs or 6200 RPMs???
max torque is developed when the most air is pumped into each cylinder, max. HP is produced when the total airflow through it is produced at high speed.
forget horsepower, build your engine to be a torque monster, that is in the RPM range you will driving around on.
torque is what moves your car, not horsepower, it took me a long time to get over the horsepower game and build engines for torque.
i bought some high quality CHEAP aluminum heads off ebay from a guy who builds them himself ($599 +48.50 shipping), astrodokk came over and took a look and said "i have to get a pair of these", we where on the phone tonight until he found the power seller selling them, he was so impressed looking at my new heads he pulled the trigger on buying them instantly.
as a side note, i have a 60s gasser (yes astrodokk that is my "limey taxy
") it has a modified 365 HP engine. i built the engine for max HP, what do i need mid range torque for, i dump the the clutch at 5000 RPMs and row through the gears shifting at about 7000 RPM on the muncie. best time--10.78, top speed-128 MPH. guys, PM me if you want the scoop on these heads, i hope this doesn,t get me sent to banned camp!!
. LATER, or if not if i get banned....
I have a 350 too...
