I'm rebuilding the '65 350
#41
kensmith, the dokk says you are really nice guy, so no disrepspect-nor to you astrodokk. i ran the numbers on his CR for a 350. the heads he bought have 64 CC chambers, the numbers on a CR calculator came in at just below 10-1. (the same heads i bought off e-bay)
now the dokk is going to a 383 stroker, this changes the CR.
my engine is a 383 stroker, according to the specs-383 CI, 64 CC heads, an .039 head gasket, pistons .015 down in the hole-this works out to 10.71 on my engine. i will modify the cambers to bring it down to 10.5 or 10.3 (still thinking about that). it's like 2 or 4 CCs out of the combustion chamber.i recomended that dokk go with dished pistons to keep the compression on the safe side--but asstrodokk, this will kill your quinch. the dished piston i showed you will not have as much cuinch. the flat tops would be much better for quinch, go with fat tops and modify your chambers.
#43
Update on cam
We've finally narrowed down the cam decision to the Comp Cams Thumper series 235/249 duration @ .521/.507 lift. The heads are good to .600 lift. We talked about this one the most because it's a retro fit hydraulic roller that maximizes that loby sound (like Dave's there), yet doesn't compromise on the vacuum, power, driveability, but increases torque and horsepower. The range is 2200-5900. It'd be nice to get the same performance out of a cam from 1800-6700! I haven't found any. Thanks to all for your participation in this build.
#44
Received 1,859 Likes
