Disassembling a 283
Old Dec 7, 2008 | 10:01 PM
Panama 58's Avatar
Panama 58
Default Disassembling a 283
I am disassembling a 283 and have removed all main caps except the rear one. What is the secret to getting this one out? I have removed the oil pump and the two retaining bolts, but there seems to be a pin of some sort holding the left side in place. This is my first time breaking one of these down and I don't want to screw something up. I have all of the pistons out except the front and rear on the same side. The crank is prohibiting me from getting at the studs. Thanks for the help.
Panama
Old Dec 7, 2008 | 11:15 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Leave one of the main bolts in the cap and hit it from the side with a soft hammer, it will break the cap loose.
If the main cap is far enuf lose so you can see a pin, a couple brake adjusting tools make nice pry bars to ift the cap off.
You should be able to rotate the crank to access all rod bolts.
Doug
Old Dec 8, 2008 | 08:31 AM
Panama 58's Avatar
Panama 58
Thanks. I will give that a try.
Panama
Old Dec 8, 2008 | 08:52 AM
MikeM's Avatar
MikeM
Don't forget to mark all the main caps in numerical order what web they came off of. Same way with the rod caps or whoever puts that back together will have a mess.
Old Dec 8, 2008 | 10:33 AM
Dick Horzen's Avatar
Dick Horzen
No mixing matched parts!
Old Dec 8, 2008 | 11:49 AM
Panama 58's Avatar
Panama 58
All of the rest of them are off, numbered and mounted on a piece of plywood in order. Thanks for making sure.
Panama
Old Dec 8, 2008 | 11:54 AM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
If it's an early 283 with the rope type rear main seal, they can stick pretty well sometimes. A good whack with a deadblow hammer will loosen it up.
Old Dec 8, 2008 | 06:34 PM
Panama 58's Avatar
Panama 58
Default Got it out
It was a piece of cake. Got it out this afternoon with no problems. Thanks guys.
Panama
Old Dec 8, 2008 | 06:44 PM
Bill Irwin's Avatar
Bill Irwin
I love a happy ending.
Old Dec 8, 2008 | 07:35 PM
john neas's Avatar
john neas
The main caps are marked from the factory. I did not believe it. Gayle Parsons told me to look. They are faint but they are there. Takes the fear out of assembly.
Regards
What is the best procedure to mark rods and caps?
Old Dec 8, 2008 | 07:52 PM
muncieman's Avatar
muncieman
Regards
A small number punch, mark the rod and the cap where it parts. On the outside is the place I mark them.
To Disassembling a 283
