427 390 HP Engine Temperature Issues
The car came w/ a dual point , no vacuum advance, that was scavenged from a 1962 327 - 340HP Vette motor.
Let's take the eBay purchasing of a 40 years old dist & rebuilding it off the table for now! Thanks!
Let's get to the problem:
I purchased the following Infrared Thermometer
http://www.harborfreight.com/cpi/cta...emnumber=93984
The infrared thermometer reads 200 deg & stock gauge read 210 deg which is middle of the gauge. I'm running all stock cooling components with a 160 Mr. gasket high flow Tstat.
How much heat can this motor take?
I would like to see 180 Deg on 93 Octane gas.
Does anyone have a stock 1966 427 390 HP engine that runs in this range.
When I put my hand on the front of the radiator to measure temp it seems to be working fine!
top of the radiator is hot, middle warm, bottom cooler.
The radiator is in excellent shape - Harrison stock brass!
Any suggestions that may help using stock parts?
I am guessing. Is your mechanical advance and vacuum advance listed in DISTRIBUTOR DEGREES and the initial in CRANKSHAFT DEGREES?
14 crank?
I caught that too!
If the original rad is still being used that would be the first place I'd start looking at to replace.
After all these years the corrosion build-up inside is enough to greatly diminish cooling capacity.
Time to call DeWitts for a nice aluminum replacement unit.
I don't know if you have the correct radiator or not. Do you?
Seeing dramatically different temps in different areas of the radiator would be a red flag to me as far as flow.
Time to call DeWitts for a nice aluminum replacement unit.[/QUOTE]
The current GM Harrison Radiator was purchase from a local Chevy dealer in 1990. Yes, I realize it is 18 years old but it has spent many years out of the car. I flushed it out during a recent engine rebuilt & it was perfectly clean! No rust, just clean antri-freeze. I used a high pressure water nozzle & water flowed through the radiator effortlessly.
Where is the most accurate spot to measure engine temp with the laser thermometer? Base of the brass sending unit? Orange painted Thermostat housing? Black painted Radiator inlet?
Any other way to verfiy water pump & radiator functionality?
Thanks in advance for helping!
Andy
6:40 138 178 203 210 118 200 84
6:42 126 197 207 210 141 206 112
6:44 157 200 212 212 126 214 111
6:46 158 203 212 212 147 212 83
6:48 164 202 213 212 149 211 97
6:50 154 202 207 212 140 197 83
6:52 152 201 207 212 140 211 97
6:54 174 209 219 216 160 212 108
6:56 174 209 219 216 160 212 100
6:58 176 213 220 216 166 213 110
Sum 1573 2014 2119 2128 1447 2088 985
Avg 157 201 212 213 145 209 99
Is this motor runnig hot?
The Factory recommends a 195 Deg T-Stat?
Mid gauge - 210 Deg
The avg temp out of the rad is 99 Deg!!
Temp going to heater core is 209 Deg
Gauge & T-Stat are almost the same - maybe the gauge is working!
Even though it never returns to the lowest mark on the gauge.
It seems like everything is working correctly.
However, I would like to see lower tempatures.
Anybody have any info to share on this?
Andy
Last edited by dewhurstaj; Dec 13, 2008 at 02:52 PM. Reason: Easier to read & understand - the columns did not line up.
You information kinda' runs together and is hard to decipher but I'll give you credit for much detail.
My 66 BB , W /alum heads runs cool .....180 thermostat , I actually install a 190 thermostat from Nov to April >>.In my case MSD ignition & pro billet dist, 12 initial 24 Dist (all in 2800 rpm) & full vacume ........Have owned since 1994 never has overheated , I drive minimum 1000 miles a season .......
The Dog
I edited the data to make it easier to read!
All of the reading were obtained ~1" away from the objects except the radiator temp out which was ~4" but still w/i range of the Infrared Thermometer.
Does anybody know the coolant temp spec of a big block chevy Radiator inlet & radiator outlet?
If the temp data is correct - it seems like it should be more then enough to cool the motor!.
Again! Thanks for helping!
