Acceptable Pulley Misalignment?
Old Dec 11, 2008 | 09:09 PM
Mikey65's Avatar
Mikey65
Default Acceptable Pulley Misalignment?
What are acceptable parameters for pulley misalignment? The alternator is forward a bit, but I am afraid if I bring it back, the belt will encroach the lower radiator hose...
Old Dec 11, 2008 | 09:12 PM
Hitch's Avatar
Hitch
Post a PIC...
Old Dec 11, 2008 | 09:35 PM
MikeM's Avatar
MikeM
If the alternator belt is in the correct position and it hits or comes close to the bottom radiator hose, the hose is probably installed backwards. Common mistake.
You shouldn't have any visually obvious belt misalignment.
Old Dec 11, 2008 | 09:37 PM
TJefferson2020's Avatar
TJefferson2020
Mine is the same way - I never thought about doing the hose the other way - I can't imagine that would work but I'll check it out. That is one difficult hose to install...
Old Dec 11, 2008 | 10:23 PM
Ron Miller's Avatar
Ron Miller
Believe it, it's a fact!!
Old Dec 11, 2008 | 10:25 PM
Hitch's Avatar
Hitch
Yep that lower hose can be put in backwards and guess what... Then the alternator belt chews through it in short order...
Old Dec 11, 2008 | 11:46 PM
Ironcross's Avatar
Ironcross
Not sure of your engine size but is this the upper or lower. I dont see how either could be backwards except some companies double up on hose applications to fit more that one car by trimming the ends when demand slows down for one or the other.
But sometimes you can loosen one of the clamps and twist one way or the other enough to clear the belt without removing anything...
Old Dec 12, 2008 | 01:23 AM
Mikey65's Avatar
Mikey65
I will post pics this weekend.. wife stole the camera and went to vegas. But the hose is the lower, and a correct GM repo. I will have to check it out as I can't see how it could be installed backwards... It has RAD -----> with the arrow pointing to the radiator which I assumed meant install the arrow pointing towards the radiator which I did lol
Old Dec 12, 2008 | 06:45 AM
MikeM's Avatar
MikeM
If you have an original factory correct shaped bottom hose, That hose will go on backwards slickern' a minner's p......r.
I don't say that's your problem for sure but it's likely. The easy way to put that hose on is to stick it on the radiator, tighten the clamp and then install the radiator. Short of that, slide the hose on the radiator outlet with the clamp loose on it, then tighten it from underneath the car.
Old Dec 12, 2008 | 08:22 AM
ctjackster's Avatar
ctjackster
The easy possibility of the lower rad house going on backwards on C2 SBs is known and often reported here, the only problem with doing that (it certainly makes the connection just fine that way) is it puts the hose too close to the belt, and any flexing in the belt chews the hose.
My only other comment here is that, if you really do have some amount of visually noticeable pulley misalignment (front to back) - the answer to your question in the title of this thread is "no amount of pulley misalignment is acceptable" - you should track down the problem and rectify it (use the correct combination of pulleys, move the alt forward or backward, etc.)
Old Dec 12, 2008 | 08:59 AM
BarryK's Avatar
BarryK
yep, the correct lower rad hose CAN EASILY be accidently installed backwards and as mentioned it makes the alternator belt rub against it and will chew thru it.
Believe me, i know this from bad experience.........
If your alt belt is too close to the lower hose you can be pretty sure the hose is installed backwards. flip it and you will see how much additional clearance you gain.
Old Dec 12, 2008 | 11:27 AM
TJefferson2020
I'm going to tackle this over the holiday vacation. What sucks is that I just installed a new motor and had the radiator out! I just got it all put back in.... Corvettes. Don't you just love them?
Old Dec 12, 2008 | 11:36 AM
BarryK's Avatar
BarryK
for me, the hardest part of reinstalling the lower rad hose was getting it to slide past the shroud on my '65 to come down to the lower rad housing. It just wouldn't slide at all no matter how much I pushed and pushed and fought it, just a tad too tight. Than I smartened up and sprayed some WD40 on the hose and she slide in there as easy as pie with no fuss.
Old Dec 12, 2008 | 01:16 PM
64tux's Avatar
64tux
after reading this post i checked mine, and guess what? it was on backwards!! changed it around and now i've got plenty of room!!!!
Old Dec 12, 2008 | 07:22 PM
Kensmith's Avatar
Kensmith
Well, my lower hose has an arrow, GM part number, and looks like this so you can't make a mistake:
Old Dec 13, 2008 | 12:24 AM
Mikey65's Avatar
Mikey65
Ken that is EXACTLY how mine is.... GM with the arrow..
Old Dec 13, 2008 | 10:14 AM
Kensmith's Avatar
Kensmith
If your belt is touching the hose, get a slightly longer or shorter (can't remember) belt which will raise the alternator, pushing it towards the motor and give you a little more clearance.
To Acceptable Pulley Misalignment?
Old Dec 13, 2008 | 05:09 PM
66jack's Avatar
66jack
OR....mount the alternator on the Drivers side?
Old Dec 13, 2008 | 08:59 PM
magicv8's Avatar
magicv8
There's a sheet metal guard on A-C cars that protects the rad hose from
being chewed up.
I took an alternate solution and inserted a piece of stainless tubing
there. Now the belt just polishes the stainless when the revs go high.
Old Dec 14, 2008 | 01:55 AM
mechron's Avatar
mechron
HOLY COWS!!! ken, if i was you i would toss that fan in your pic, the construction of that fan scares the crap out of me...
