lilblueribbon
Old Dec 13, 2008 | 11:26 AM
lilblueribbon's Avatar
lilblueribbon
Cruising
Default lilblueribbon
I had an acident with my 61'. Since its already a resto-rod, I thought a57' nose would be cool. Does anybody know if it fits? I know there is a difference of 8" in overall lengths, but is it in the rear or front? Wheelbase on both is the same. Help!
Old Dec 13, 2008 | 11:45 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
the fiberglass may fit but you will have problems with fitting the hood.
personally, i think the 57 front with the 61 'ducktail' rear would look strange
Bill
Old Dec 13, 2008 | 11:59 AM
vetrod62's Avatar
vetrod62
Like this?
Old Dec 13, 2008 | 12:14 PM
53 Blue Flame Brett's Avatar
53 Blue Flame Brett
Default 61 to 57
Yes. It can be done IF you use the entire frontend. If you want to retain the 61 dash, you'll have to splice the front end at the hood ledge area. You'll need to modify the upper cowl ends a bit also. Very easy to do. 53-57 style inner fenders, radiator panels and hood would be needed. Also 53-57 hood hinges.
You'll probably save money putting it back stock, IMO.
Good luck with whatever you do.
Old Dec 13, 2008 | 12:25 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Originally Posted by vetrod62
Like this?
Jim
for once i'm at a loss for words...
Bill
Old Dec 13, 2008 | 08:13 PM
jdk971's Avatar
jdk971
it is your car do what you want to do. but i love the 61 and 62 styles. jim
Old Dec 15, 2008 | 12:14 PM
paulywannafly's Avatar
paulywannafly
If I can make those crummy german panels fit on the MAKE ROOM
01 conv owned by Sixty4 this should be a cake walk installing a 57 nose on Kens 61. Thanks for the input guys Paul
To lilblueribbon
