AMP Performance
Old Dec 17, 2008 | 02:01 PM
Tonytz06's Avatar
Tonytz06
Default AMP Performance
I did a Tremic conversion on my 63 coupe and wanted to say the guys at AMP Performance are great to do business with.
Old Dec 17, 2008 | 02:28 PM
midyearvette's Avatar
midyearvette
did my conversion 2 years ago and really like it. fyi....next time you have the car out, when cruising in 4 th gear , pull back on the stick firmly......if you get a slight vibration in the shifter, your tailshaft is too low, simply add thick washers under the rear mount until the vibration goes away......good luck
Old Dec 17, 2008 | 03:13 PM
Tonytz06's Avatar
Tonytz06
Thanks for the tip. I will remember that. I am doing a body off restoration with a few upgrades. I hope to have this back on the road by early spring.
Thanks again
To AMP Performance
