Part name - Help
Old Dec 19, 2008 | 06:59 PM
LSUvetteguy's Avatar
LSUvetteguy
St. Jude Donor '10
Default Part name - Help
I'm working on a 67 rdster and I'm looking for a missing body part but I don't know what to call it, so I'm having trouble finding one. The missing part is located on the interior kick panel and should support the fresh air vent door. It's fiberglass with a flange on the end toward the interior that is bonded to the cowl inner fiberglass panel.
Old Dec 19, 2008 | 07:03 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
how could that part be missing. I dont belive anyone makes that. so you will need to make your own or find a $doner body$
Old Dec 19, 2008 | 07:09 PM
LSUvetteguy
St. Jude Donor '10
It's a new one on me, I've never run across a car missing one. I'm sure I can fabricate something if necessary but the owner wants to do it all original. A doner car may be the best way.
Old Dec 20, 2008 | 04:50 AM
67L36Driver's Avatar
67L36Driver
WTF?????????? It's not going to be original to the car anyway so why get so ****?
Old Dec 20, 2008 | 10:26 AM
wombvette's Avatar
wombvette
AIM calls it an "outlet" , part number 3899220. Parts book calls it an "outlet, dash panel vent air". Plenum air outlet might be a more common name.
Old Dec 20, 2008 | 02:52 PM
JohnZ's Avatar
JohnZ
If you mean this housing/outlet that encloses the air vent valve, you'll have to get one from a donor car; they're not reproduced.
Old Dec 20, 2008 | 04:32 PM
LSUvetteguy
St. Jude Donor '10
Thanks guys. Now that I know what to call it I also know that it's not available as a reproduction. I located a possible donor cowl section and the fellow will check Monday to see if the part is still there. If not, it shouldn't be hard to fab with metal and a little glass. Thanks again for the help.
Old Dec 20, 2008 | 11:18 PM
splidecision63's Avatar
splidecision63
Hello Eric,
I found a corvette junk yard in Seabrook Texas. They were able to help me with a few Parts. call Jay 713 253 0475, if your other contact falls thru.
George
To Part name - Help
