The ammeter in my 63 doesn't work. I notice that the black wire (with a gold metal tab at the end) on the ammeter capacitor is just hanging there. Its not plugged into anything. Does anyone know where it plugs in and it this would be the reason the guage doesn't work?
The capacitor just slips into one of the female terminals that connects to the gauge, before the terminal is connected to the gauge. It has nothing to do with the operation of your gauge.
How do you know the gauge doesn't work? The one on my 65 barely moves as it is.
I don't know for sure about 63, but suspect it is the same as my 65, in which this gauge does not measure amperage like on pre 63 models, but instead measures a voltage difference between a lug on the horn relay, and the starter.
Remove the connection from the gauge, and with the car running, measure the voltage between each connector, and ground. If you get voltage on both of them, and yet your gauge does not move at all, then maybe the gauge is bad.
When my gauge was bad, the person who rebuilt it told me to quickly put a 9V battery across the terminals and see if the needle moved, then connect the battery 180 degrees to swap the +/- and see if the needle moved the other direction. If it did, the gauge was likely OK.
You can see how that capacitor is installed in this photo. Ignore the funky wiring you see in this photo, that's just a 2 Amp fuse I added to protect the gauge
Well the gauge just stays at 0 all the time. Even when I honk the horn or turn on the headlights. It never fluctuates at all. I will check to see if there is voltage at each connector as ou have suggested and if so will proceed with the "9V battery test". Thanks for your help.
Just don't do the 9V test any longer for an instant. You don't want to hold the battery in place while you look at the gauge, take measurements, call your neighbors, etc Just touch the battery terminals to the gauge and see what the gauge does.
Hahaha......yeah I figured it would be best to just flash it across. I'll let you know how it turns out.
Cheers,
Zora
This has been discussed at length. Use a 1.5 volt battery.
Some say that the 9 volt battery doesn't have enough current to move the gauge and others (like me) recognize that 9 volts is way to much and if the battery has/had the amperage, could peg the gauge (and harm the needle/movement).
BTW, due to the "open design," the '63 and '64 gauges are a cinch to rebuild yourself. Typically, the windings burn open. It is a simple matter to disassemble the gauge, and rewind the armature. Just use a magnetic wire similar in gauge to what you remove, and count the number of windings while disassembling so you can put the same number back on. There are not that many windings to deal with (only about 23 turns if memory serves).
If the gauge check is OK (deflection in both directions), it's probably a bad connection/corroded terminals for the two sense wires in the multiple connector on the engine compartment side of the fuse block; very common midyear issue.
