58 battery location
Old Jan 8, 2009 | 08:52 AM
sodfather's Avatar
sodfather
Default 58 battery location
I want relocate the battery to the trunk fenderwell on my 58 . standard optima is to big , can anybody who has done this help with size or type .
Ken
Old Jan 8, 2009 | 09:26 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
there are different physical size batteries that should have sufficient amps to start your engine, so the first thing i suggest you do is find out the physical size of various batteries available, go to a store (Walmart or an auto parts store where they have a large supply of batteries and make measurements), then determine how big a space you have to put the battery in. (remember, you should make a stainless steel tray to sit the battery in and hold it down, so you have to make allowances for being able to get the battery in/out of the tray in that space.)
this is the battery placement in my 62
Bill
Old Jan 8, 2009 | 10:27 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Someone right here on CF posted pictures of a battery relocation to the trunk several months ago. It was a beautiful, very professional looking mod (actually, I don't think the factory could have done a finer job!). It was soooooooooooo nice, I've even considered doing it to the 56!
Maybe that person will chime in soon.
Tom Parsons
Old Jan 8, 2009 | 10:33 AM
sodfather's Avatar
sodfather
it seems apparent that there is more room in a 62 than in a 58 , so i will have to look for a smaller battery , or cut out in the spare tire well to accommodate an optima .
Ken
Old Jan 8, 2009 | 03:00 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Tom Parsons
Tom
2 people have relocated the battery, in 2 different ways (and posted pix).
Charles Bernhardt posted pictures of what he had done when i was looking to relocate my battery after my EFI conversion (most of the electronics are where the battery was); and that is how i relocated mine.
Herb (First Gear) made an offset pocket in his spare tire well to locate his battery.
both were VERY well done...
Bill
Old Jan 8, 2009 | 08:54 PM
vetrod62's Avatar
vetrod62
Ken
You are correct on the trunk size. The only trunk mounted batteries I have ever seen, other than Herb's in 56-60s, have had the battery bolted in the spare tire tube. Both my '62s have the batts in the trunks.
The black car has the batt. in a steel box for NHRA rules and the red car has a little more complex installation in the trunk.
Old Jan 9, 2009 | 08:30 AM
David Schuster's Avatar
David Schuster
I am contemplating the same in my 60. My thought is to extend a tray into the wheel well so that the battery will be completely into that area.
Many of the sealed batteries can be on their side which may help reduce the vertical dimension. Also, there is a group 95 battery but the most powerful I have seen is 550 cca but that should do the job in most cases.
See Jegs or Summit catalogs.
Dave
Old Jan 9, 2009 | 09:19 AM
sodfather's Avatar
sodfather
On a related subject , as part of the restomod project I will need to find a place to put the computer . engine bay ? kick panel ? trunk ? any thoughts .
Ken
Old Jan 9, 2009 | 09:37 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Ken
mine is located on the engine side of the firewall in the area where the battery used to be. splash pan was made removable for easy access.
i remember that AZDoug put his on the bulkhead behind the passenger's seat.
Bill
Old Jan 9, 2009 | 09:41 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Are you folks doing this for greater accessibility or to improve weight distribution (as Shelby did on the '65 Mustangs)???
Old Jan 9, 2009 | 09:43 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
for me, accessibility; that is a terrible place for a battery when the time comes to have to change it out, especially after adding a/c...
Bill
Old Jan 9, 2009 | 10:09 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
My computer is the same place yours is, above where the battery used to be. No way to get wires from engine to behind the seat.
I did make a terminal strip block that sort of looks like a battery, from the top, that is 4" tall and held in place by the old battery retainer, that the trunk monuted battery cables terminate to, and all the electrics feed off of including the hot cable to the starter.
The tech inspector at the last drag race didn't pick up that the battery was somepalce else, of course all those EFI wires, that are missing in your picture, help obscure it.
Doug
Old Jan 9, 2009 | 11:22 PM
vetrod62's Avatar
vetrod62
Ken
I have mine behind the drivers seat. EZ to get to, protected from the elements, but my seats tilt forward. The tilting seats are handy for many reasons. The passenger seat also has electronics behind it also.
Old Jan 9, 2009 | 11:25 PM
vetrod62's Avatar
vetrod62
Primary reason is weight distribution, bonus is accessibility for me.
Old Jan 9, 2009 | 11:36 PM
vetrod62's Avatar
vetrod62
Originally Posted by AZDoug
The tech inspector at the last drag race didn't pick up that the battery was somepalce else, of course all those EFI wires, that are missing in your picture, help obscure it.Doug
The tech guy probably did not know where the batt. went. I passed the first couple of times I raced, until they got used to the car. Also they will want an emergency shut off switch, accessible from the rear of the car. You can see mine in the black car picture, but it is not legal (mine is there for instant disconnect when the car is not in use). To make it legal I would have to drill a hole thru the rear of the car and attach a rod to activate the switch, FAT CHANCE of that.
Old Jan 10, 2009 | 12:23 AM
AZDoug's Avatar
AZDoug
Exactly. No holes in my car.
I don't/won't race much, especially with the new paint. Any way, the Friday night drags are supposed to be run what ya brung, even though last time some tech ******* told me I needed extra long lugs and see thru lug nuts on my car, but the turbo Porsche, and everything else there didn't get a lug nut inspection.
He even asked me where my fire suit was.... I looked at him like he was from Mars.
Doug
Old Jan 10, 2009 | 12:27 AM
AZDoug's Avatar
AZDoug
Let me rephrase my earlier comment.
No easy way, without spending some serious hours building a wiring harness, to put the computer behind the seat.
Yes, the flip seat helps, installing a factory seat is a pain.
Doug
Old Jan 10, 2009 | 12:52 AM
vetrod62's Avatar
vetrod62
Doug
The lug nut rule and lots of others are because your car is modified. The turbo Porsche is stock. He skates on lots of stuff. They do that because too many fools will change wheels and put lugs on that only catch a few threads. The tracks have lots of insurance requirements to stay in business. Fire suit? He must have thought your car was really fast. As for the lugs, the 7/16" ones can be easily broken.
We rent the track several times a year, only 20 cars, good times, but the same rules apply as a national event for their insurance responsibilities.
I went for about 30 years not drag racing because of family,building a business, and what ever, now my greatest fun is racing these old cars against cars that are equal to mine.
Old Jan 10, 2009 | 01:00 AM
vetrod62's Avatar
vetrod62
Doug
Yes, I built my own harness. The flip seats are great for so many reasons. I have probably pulled the seats 10 times in the black car for seemly minor reasons.
To 58 battery location
