Oil filter cross reference
Old Jan 16, 2009 | 11:06 PM
CabSav's Avatar
CabSav
Default Oil filter cross reference
My 3855961 BB arrived here with a NAPA 1515 spin-on oil filter on it , so I presume it has been converted at some stage, but because NAPA parts are not available in Ozzy, I wonder if anyone could help me with a cross reference to AC Delco or Ryco please? I've already tried google & yahoo with no joy.
Thanks,
Peter
Old Jan 16, 2009 | 11:44 PM
Plasticman's Avatar
Plasticman
I checked NAPA online and did not find a 1515 in any of their different series of oil filters.
Typically, the conversions used later model AC (GM) filters. Recommend you take it off and compare the diameter and the threads to see what matches. No rocket science here, just something that doesn't leak and filters the oil.
Plasticman
Old Jan 16, 2009 | 11:51 PM
Plasticman's Avatar
Plasticman
Further info from the below linked cross ref.:
http://www.aloha34.com/information/oilfiltertable.pdf
It shows that a NAPA 1515 = a CM 25-420
A CM 25-420 = a Wix 51515
and a Puralator PER1
and a Fram HP1
And is 6-1/4" long, has a thread of 3/4" with 16 TPI (threads per inch), and an "O" ring dia. of 2-5/8"
Plasticman
Old Jan 17, 2009 | 12:02 AM
Plasticman's Avatar
Plasticman
This is directly from one of NAPA's website (they sure don't make it easy, seeing as I could not find a 1515 filter off their first site):
http://www.napafilters.com/filterloo...sp?PartNo=1515
Click on the 1515 shown on the above web page, and the below info will come up (as a pop up).
Part Number: 1515
UPC Number: 765809139695
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 1773)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 290
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Old Jan 17, 2009 | 04:53 AM
CabSav's Avatar
CabSav
Thanks for all that Plasticman, I had already found the 1515 on the Napa website with all the dimensions, but it was the conversion to another brand I was fixated on. With your help & direction I have used the measurements in the Ryco Aust. website & found a match.
Thanks again for your help.
Peter
To Oil filter cross reference
