The ammeter in my '66 L79 coupe is not working. Trying to start with the easy things first (I would rather not remove and disassemble the instrument panel and replace it), I notice a condenser body in a bracket under it, but no wire coming out of the condenser to anywhere. I also notice from pics posted here that the wire from the condenser should be hooked to the left post of the ammeter. So, does anyone know where to get a new condenser for this? Thanks for any help.
Most vette vendors should have them. Long Island Corvette Supply shows it as part number 53-03G for $20
However, that capacitor is unrelated to the performance of the gauge
The gauge just measures a voltage differential between the 2 wires going into it. One wire comes from the starter, the other from the voltage regulator.
Remove the wires from the gauge and with the car running, measure the voltage at each wire to ensure the gauge is getting a signal
OK, thanks will do that. Yes, I guess if I wasn't so old fashioned and out of date, I would have searched the new name for condenser, capacitor, and found a previous thread on this problem recently. But tell me, what does this capacitor do if it not involved with the gauge and yet hooked to it? I know capacitors are supposed to store electricity, right? What function is this thing doing that is not hooked up?
After testing, the right side of the harness has votage, the left (the side the capacitor is hooked to) does not. I will chase that wire down now. Thanks.
small correction - one Battery meter wire gets 12volts at the starter solenoid, the other gets 12volts at the horn relay.
Both wires are always live whenever the battery is connected, and only
a 67 harness has fusible links. If your Battery meter is still okay, I
advise putting a 1 or 2 amp inline fuse on one of the meter terminals.
But tell me, what does this capacitor do if it not involved with the gauge and yet hooked to it? What function is this thing doing that is not hooked up?
Capacitors prevent voltage spikes. Maybe in this case it damps the gauge.
It absorbs transient voltage spikes from the ignition that can cause "pops" in the radio speaker; it has nothing to do with gauge function.
