Vent window install
Old Jan 23, 2009 | 07:00 PM
ren's Avatar
ren
Default Vent window install
I just got my vents back from Charlie Santarelli. They look brand new.He does great work, What's the trick in re-installing them. Speciffically how to you align them properly? Left side went in fine. Window cranks smoothly so I put the panel back on. Now when I close the door the gaps aren't right. On the right side, I can't seem to keep the window in the track. Do you tighten the bottom stud before or after the top? They sure came off easy enough. I dread taking that panel off again.
Old Jan 23, 2009 | 07:18 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Unfortunately the panels should not go on before the tracks and channels along with the vent assembly are checked for fit. The procedure is outlined in the Service manual, but is long. Basically loosen up all the mounting bolts just enough to move things around. You may have to shim at one point. Check your overall door gap front and back. This should be the starting point for everything to fit properly. Hope this helps. Dennis
Old Jan 23, 2009 | 08:11 PM
ren's Avatar
ren
Thanks.That makes sense. It seems like every time I do a project, I have to do it two or three times before I get it right.
Old Jan 23, 2009 | 08:19 PM
midyearvette's Avatar
midyearvette
vette gremlins again.....
Old Jan 23, 2009 | 08:26 PM
nassau66427's Avatar
nassau66427
From: going faster miles an hour...with the radio on in browns mills new jersey
In addition to aligning your vent window to the windshield, don't forget to align it to your top.
I was very pleased with the job I did on my vent windows until I put the top up.
At least it was much quicker doing the job the second time around.
Old Feb 7, 2009 | 06:33 PM
ren's Avatar
ren
Wll the temperature finally got above 40 so I got back to installing the vents. The drivers side is acceptable. It's not perfect. The window binds slightly at the top. The passenger side is another story. I must have spent about 3 hours on it. The window binds prettty good, almost make a grinding sound toward the top. I've loosened everything several times,tried to re-position the frame. It's very frustrating. I might just need another set of hands. Maybe if I get a neighbor to hold the frame while I crank and tighten. I guess maybe this is why they make beer.
To Vent window install
