"Removal of tranny pilot bushing"
What would be the easiest way to remove the transmission pilot bearing out of the end of the crankshaft. Looks like it requires some kind of special puller. I finally got everything torn down in an effort to solve this chattering/chaffing sound while coasting in gear, but I haven't really found anything yet. The T/O bearing dosen't seem to be bad, although IMO it dosent seem to be retained on the clutch fork very well. Very loose, sloppy. I intend on changing the clutch fork and T/O bearing just as a precaution. I do want to change the pilot bushing while I'm in the area. The clutch/pressure plate is in real good shape, very little wear, so I'll pass on that and put the money somewhere else. Thanks, George:
You know I don't know the correct procedure for getting the bearing out, but this is what I did.
Found a punch that just fit into the center hole.
Pack the bearing with heavy grease.
Hit the punch with a hammer.
Punch compressed grease... and bearing popped right out.
Helpful hint... wrap end of crankshaft with a rag so grease won't splatter.
Received 1,844 Likes
If you don't have a tap that size, just screw an old lag bolt in the bushing and use the bolt as a handle to work the bushing out of the crank.
That grease can get awful messy.
If you plan on doing this job a few more times it may be a good investment to get a pilot bearing puller such as OTC's 7318 . Proper tool for the proper job.
I bought the OTC puller and it didn't do jack s... 5/8 threaded bolt ground a tinch to fit, play dough, and few whacks with the hammer is all it takes.
larry
larry
Somebody should write this up for the tech tips section as it comes up quite often. I tried all the hydraulic methods and a puller with no luck. Didn't want to use a tap as I feared a broken tap would be worse. I cut a slice with a hacksaw blade.
Have never tried the clay, but see it working only on a bushing that is not worn much (and certainly not one with an ovaled bore, since the "piston" needs a straight round bore for it to work against).
Plasticman
Received 3,777 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
