63 Engine-Correct?
Old Jan 25, 2009 | 01:37 PM
Jvmc's Avatar
Jvmc
Default 63 Engine-Correct?
This board is great for getting a handle on what is wrong with things on certain year cars, so here is another chance and appreciate the help.
Below are a few pictures of a engine in a SWC and wanted to know what is right/wrong and suggestions to get it as close to correct without going overboard. The valve covers have the seam running down the "O" which I don't believe is correct for '63. Also, it is not a numbers matching car so keep that in mind.
Thanks for your help in advance.
Old Jan 25, 2009 | 01:44 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
what is on the stamp pad for the HP that dictates how the motor is dressed out. for one the exhaust manifolds should be natural cast in color
Old Jan 25, 2009 | 02:16 PM
C2Driver's Avatar
C2Driver
I blew up the 2nd pic and it looks like a 350 c.i. head, i.e, no pyramid or camel hump. If that's the case, it can be dressed to suit the OP's taste.
- Pat
Old Jan 25, 2009 | 02:25 PM
Nowhere Man
- Pat
looked at again and your correct there is no breather tube from the intake to the air cleaner base either. but the OP did ask about the correctness of the engine compartment
Old Jan 25, 2009 | 04:00 PM
boulderkid's Avatar
boulderkid
Default '63 Engine Compartment
For starters, incorrect brake master cylinder (correct ones are pretty big bucks). Also, fan clutch incorrect (?)
Old Jan 25, 2009 | 05:00 PM
rick charles's Avatar
rick charles
Default 1963 eng. comp.
Alternator is indexed wrong way .... Flat side should be on top....
Old Jan 25, 2009 | 05:01 PM
Jvmc's Avatar
Jvmc
Originally Posted by nowhere man
what is on the stamp pad for the hp that dictates how the motor is dressed out. For one the exhaust manifolds should be natural cast in color
f0509re
Old Jan 25, 2009 | 06:31 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Jovi, The water neck looks like the up angle is too high as compared to some text books I have and this would led to an incoorect top hose. The vacuum advance line has an odd upward turn, under the choke coil. Dennis
Old Jan 25, 2009 | 06:36 PM
Glasshole's Avatar
Glasshole
The PCV valve is located at the back of the block in '63. This one looks correct as you can see the hose running from the carb, under the distributor to the correct location.
Old Jan 25, 2009 | 06:38 PM
Jvmc's Avatar
Jvmc
Dennis you are correct, I bought the correct top hose, but the angle was too great. Just trying to clean it up and make it nice and pretty.
Old Jan 25, 2009 | 07:39 PM
TX63CONV's Avatar
TX63CONV
Old Jan 25, 2009 | 08:35 PM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
Wiriing on the alternator is wrong, no boot. I would check to see if the alternator is a replacement. Wrong dip stick. The carb return spring, no such thing as "white" return spring. Heater houses using nylon wire wraps they should be metal. Paper filter elements inside air filter, should be foam. Replacement master brake cylinder, no thumb or hex bolt using the bailer clip. Oil filer cap has no center dimple looks like repop. The bypass water plug on top of the water pump does not look correct it should be brass and havhave four diamond logos on the side. Something about the fan blade just does not look right for a 63...are the rivets round or flat? Lacking a lot of both white and black nylon wire wraps, and much of the wire is not harnessed correctly. Finally, the area around the fuel filter, the bypass house going into the intake just does not look right. Appears there is no belt tension wheel...Upper radiator house is replacement, need blue stripe.
Here is some photos of my Engine...NCRS Top Flight...Hope this helps...
Old Jan 25, 2009 | 10:20 PM
Jvmc's Avatar
Jvmc
Collin,
Thank you for posting your pictures.
I don't see the differences, mine looks exactly the same.
Old Jan 25, 2009 | 10:36 PM
bigredbrad's Avatar
bigredbrad
From: Lincoln NE Riding and Driving Corvettes since 1967.
What I noticed other than what was already mentioned is the lack of the rubber tube connecting the carb to the other half of the choke warm up tube, and the lower shielding that goes around the spark plugs. Also, I believe the bolts that hold the spacer blocks to the inner fender lips should not be painted body color. Great looking and original appearing engine compartment. Doesnt look like you have tons of work to do other than clean up.
bigredbrad
Old Jan 26, 2009 | 04:21 AM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
Isn't that an earlier model intake? My 63 has a high performance 62 manifold which has a similiar thermostat housing.
Old Jan 26, 2009 | 06:05 AM
ratmotortom's Avatar
ratmotortom
Platinum Supporting Dealership
EBVETTE. Nice job on your engine. Looks awesome. Your return spring looks white. Is it just the picture, or did you change it after judging. I fell into the white spring trap too while doing mine.
__________________
Tom Hendricks tom@budschevy.com
http://www.facebook.com/pages/Buds-Chevrolet-Buick-Corvette/176730955684255?ref=hl
Corvette Specialist Since 1993
BUDS CHEVROLET
St. Marys, Ohio
800-688-2837
WEBSITE WWW.BUDSCHEVY.COM
HOURS MON-WED 7:00AM - 5:00PM
FFRIDAY AND SATURDAY BY APPT.
OFF THURSDAYS
NCRS # 23758 Miami Valley Chapter ( Ohio )
NCM Founding Member #1143
NADA Classic Car Guide Advisiory Board Member
C5/C6 Registry Corporate Member # 5
My Corvettes. 63, 71, 73, 78.
Old Jan 26, 2009 | 07:28 AM
rick charles
Does it have the 8" balancer drilled for a crank bolt
To 63 Engine-Correct?
Old Jan 26, 2009 | 08:34 AM
Midyearnut's Avatar
Midyearnut
Default '63 Engine Compt.
The heater hose fitting on the top of the water pump should go directly into the pump not into a bushing.
Bob L.
Old Jan 26, 2009 | 09:43 AM
1KULC7's Avatar
1KULC7
Changed after judging....
Old Jan 26, 2009 | 09:52 AM
ratmotortom
That thing would be awesome even with a purple spring !! Nice work.
