67BB replace with crate motor?
I have been thinking about removing my numbers matching 67BB, replace with a crate motor and store the original. The car is a good driver and is in excellent shape, no current problems I am just worried that if I damage something in the engine BIG$$$, maybe unable to repair! Does anyone have any ideas as to a good replacement?
GW
GW
When I bought my '65 396 roadster it came with a '72 402 in the car and the original block out of the car. I have purchased the heads and other parts to complete the engine at a later date but have chosen to do the same thing and have installed a 1969 396 Camaro motor in the car. I have the same concerns about damaging the original block! Probably a good choice if you just want the car to be a nice driver! Good Luck!
I've considered the GM 454's but have read about a few people having oil control issues. Supposedly this is related to the "low tension" rings or not using honing plates. There was also a couple here that had distributer gears wear prematurely. Anyone know if these issues are still a problem?
Roy
When I had my restoration done in 03-04, I chose a GMPP 454 HO.
Its been a good engine with no problems, but if I had it to do over,
I would probably go with a ZZ454. The higher compression and
aluminum heads (less weight) would be worth the few extra $s.
The 454 HO seems perfectly OK with regular though. The ZZ,
maybe not....
Don
maybe not....
Don
I had considered doing this for my 66' 427 coupe I've owned for 29 years. When I did the restoration I had the engine checked and there was basic very little wear. Cylinders were honed and new bearing was all it needed. I decided keep the original engine in the car. It had lasted 40 + years and was still in great condition, plus with the rebuild it was brand new again. It will definitely last another 40 years until another engine rebuild. And by then I sure won't care what happens to it!!
I don't know, I just feel better when a car is all in a one piece.... instead of in boxes waiting for the next owner.
GW
GW
Steve
Although, the $23k could buy you another car.
Here's the link:
http://www.gmperformanceparts.com/En...6392&engCat=bb
Harps, that's the Anniversary Edition 427, and you're right, it's big bucks. But the zz427 essentially is the same engine with an iron block instead of aluminum...and you save about 15k...you can even order the flashy AE427 natural valve covers (GM p/n 19202588) instead of the black ones the zz427 comes with if you like the look.
