Plexiglass cleaner?
Old Jan 26, 2009 | 08:24 PM
lib's Avatar
lib
Default Plexiglass cleaner?
What is the preferred product for cleaning the rear window on a 63 Hardtop w/ original plexi?
Old Jan 26, 2009 | 08:33 PM
Tempus_Fugit's Avatar
Tempus_Fugit
Stop by your local airport's FBO and get a product called "Prist". Works great. All small airplane windows use plexglass too.
Old Jan 26, 2009 | 09:11 PM
JohnZ's Avatar
JohnZ
Meguiar's has a 2-step process made just for plexiglass and convertible back windows (can't remember the numbers, but it's on their site), and you may also find a "Novus" product at your local airport made specifically for aircraft plexi windows.
Old Jan 26, 2009 | 09:32 PM
buns's Avatar
buns
I have been using Novus products for years and I highly recommend it. Try your local plexiglass retailer, they probably sell it it. If not, you can buy it online.
Old Jan 26, 2009 | 09:49 PM
VetteRed1965's Avatar
VetteRed1965
I have been using AeroshellFlight Jacket cleaner on my planes windows for years.It actually helps polish and clean at the same time.Aircraftspruce has it online.In the search window put areoshell polish or the part number is 09-00392.Also pledge will work to clean off bugs too.
Mark
Old Jan 27, 2009 | 12:03 AM
Smokefoot's Avatar
Smokefoot
I recommend Plexus. It will remove minor scratches and reduce any haze. It's also anti static. I use it on the headlight covers on my C6 and I've used it on the rear window of my conv. C-2. It will even make tail light lenses look better. I buy it at the local Harley dealer (where I work) but it's not an H-D product. It's in a spray can, is perfectly clear, and can even be used on paint. It will leave the surface slippery like it was waxed. Highly recommended! Paul
Old Jan 27, 2009 | 12:22 AM
ml1955's Avatar
ml1955
Ty calling Tripp Plastics in Reno / Sparks, NV they sell a product for cleaning plexiglass that is killer! Used it on drawing drums and sneeze guards. If used properly, no scratches.
Old Jan 27, 2009 | 12:29 AM
jntdysf's Avatar
jntdysf
St. Jude Donor '06
I agree. It can be found on E-Bay at reasonable price.
Old Jan 27, 2009 | 07:25 PM
lib's Avatar
lib
Default These Novus products recommended?
Are these the same cleaners that were mentioned? They are available locally to me thru Tap Plastics; http://www.tapplastics.com/shop/product.php?pid=113&
Old Jan 27, 2009 | 10:28 PM
buns's Avatar
buns
Yes, that's the stuff. Novus 1,2 and 3. I would get one of each. Those are good prices,too.
To Plexiglass cleaner?
