I'm just getting ready to send my original block in for rebuilding and with all this talk about restamping I thought I would post a picture of my #'s to see what everyone thinks. Looks good to me and the serial # matches. My car is a 1963 fuelie built on April 23/63. Date code on engine is B 2 63. Opinions?
I had pulled the heads and they are the correct dated 2.02 double bump heads. Casting # 3782461. It has the correct 6 qt oil pan, correct oil baffle (that hangs from the main bolts), correct high volume oil pump, solid cam and lifters etc., etc. Guess I'll need to go back and talk with the fellow I bought the car from as he swore that it was the original engine (although he wasn't the original owner). It looked good to me however I am certainly no expert. Maybe I should get a local expert to have a look first though....
I see (what appear to be) overstamps or double stamping on some of the impressions.
Look at the 3 1 1 5 & 6 in particular, and then more "ghosting" on some of the engine code characters as well (look at the lower right leg on the "R".). And I agree with Mike that the striations of the broach marks just don't look "right".
Do you see the broach marks on the exposed dip stick tube portion of the block?
And the 5, 6, & 0 appear to be a slightly larger stamp size than the other numbers (especially the the 2nd "3").
But I won't claim to be an expert!
Plasticman
Here is a stamp from a '62 that looks very honest.
Yours looks really good, and that seems to be my only problem. The texture seems so perfect. I assume the steel wooling didnt help with that problem.
I dont think you would do that to a rare coin so I assume the same would be said for a stamp pad (thats just my opinion).
Generally the good pads I have seen have the lines (broach marks), but not so perfect and more of what I will call a block texture as this '62 has. Yours has the texture, but you see it is so much less visible than the lines (broach marks) are.
The stamping seem weak, but that could be due to a light redecking at one time. What I like is the first 3 is extra heavy, which seem to show up a lot.
I would say it is good enough for any judge, but whether John Z's friend would pass it, only he can tell with his magnifier and his pad history book.
Fantastic photo BTW.
Interesting that your "0" in the engine code portion is "O" vs "0" in the OP's stamp.
Your stamp has all the characters the same size (for each segment), whereas the OP's stamp has several that are not. And I agree that your "R" looks far better than the OP's "R" (the loop appears too large, with the angled leg added on, and it appears not to be a straight line, as though added by hand).
And the 2 "F"s in the OP's engine code stamp are 2 different sizes (in width).
I dont believe a HV oil pump is OE for any 63 engine, it wasn`t necessary for a new engine of any HP. However many aftermarket engine re builder kits often incorporate that pump in there rebuilds, incorrectly thinking its a safety valve item to use one.
Also the build window from the casting date is much longer than I would expect as approximately 1 out of 8 were FI engine builds. And when you add the 340 engine to the mix nearly every other engine was a 11-1 high performance engine. Part of the problem with to much emphasis on the numbers game that has emerged over the years....
I think what 65Tripleblack was talking about when pulling the heads, was that the broach marks should continue for the entire length of the block, and not just the pad. If these marks do not continue unbroken down the entire length of the block. then you can assume that it is a restamp. Even the little pad where the dipstick goes in should show the same marks. The machine that broached the block would have left parallel marks the entire length of the block, and the lines should be pretty much unbroken. I would guess that it might be a restamp as well. the broach marks look too pronounced and everything looks just too sharp and clean to be original. the broach marks appear too uniform and evenly spaced to me. It does not look like a typical factory pad to me.
Regards, John McGraw
I'm no expert on pad numbers, but I'll share a couple of thoughts.
1. The broaches used to deck the blocks would normally be cycled between being used, being sharpened, and then being re-used again. I suspect the marks left by the broach would vary depending on its degree of sharpness.
2. Speaking of sharpness, I wonder how much the steel wooling and perhaps higher pixel rating of the camera could be affecting the picture?
I'm not a pad expert and don't have any photos of other RF's stamped the same day to compare it to, but I don't have a problem with it. It shows the expected chatter marks and aging inconsistencies, and the broach marks don't go through the stamp impressions. Just my opinion.
I suspect that the casting date is actually B 26 3 (February 26th, 1963, Flint engine) and not B 2 63 (February 2nd, 1963, Tonowanda engine). An assembly date of March 15 is a bit more reasonable then.
I think what 65Tripleblack was talking about when pulling the heads, was that the broach marks should continue for the entire length of the block, and not just the pad. If these marks do not continue unbroken down the entire length of the block. then you can assume that it is a restamp. Even the little pad where the dipstick goes in should show the same marks. The machine that broached the block would have left parallel marks the entire length of the block, and the lines should be pretty much unbroken. I would guess that it is probably a restamp as well. the broach marks look too pronounced and everything looks just too sharp and clean to be original. the broach marks appear too uniform and evenly spaced to me. I would guess that some sort of uniform abrasive would be responsible for such a pattern, and not the random nicks on the broach blades that normally leave the grooves. It does not look like a typical factory pad to me.
John,
I agree. In addition, by the time the block got to the end of the broach tunnel, the finishing teeth tended to be wider and flatter, leaving less of a bar-coded effect. Also, I would expect more lumps and bumps from 40+ years of surface corosion.
Andy
Yes, the casting date #'s are fairly evenly spaced so it could very well be B 26 3. Didn't know if they used one or two digits to indicate the year. At any rate I'm going to carry on with the rebuild. I certainly didn't pay premium dollars for the car so I'm not too upset that this could possibly be a restamped block. Guess next time I'll check all this out ahead of time. Thanks for the opinions........
Bob
Bob,
Sounds correct. I think Flint engines had a single digit denoting year, while Tonawanda had double digits for year (from "Corvette by the numbers").
Andy
