Need Some Engine/Intake Advice
Rebuilt the engine from scratch. Started up and ran like a charm. After a while, I was in the process of getting the timing set up and noticed sludge seeping out of the overflow outlet in my new alum radiator. Checked the oil fill and it was milky white on the dipstick.
After pulling the intake, it appears that either the gasket around the rear water jacket didnt seal (FELPRO gaskets) or the manifold is warped (havent put a straight edge to it yet).
I have had all kinds of issues with this intake (picked it up used). I cracked it while installing the filler tube (my fault--got it fixed) but it has a stripped water neck thread and a stripped dristributor hold down. I am very tempted to substitute with something else and looking for suggestions. I would like to keep my carburetor (had it rebuilt) and everything else stock looking. Edelbrock Performer #2101 looks to be a stock replacement. Any suggestions?
Secondly, any thoughts on water getting into the lifter valley? I am hoping that it just didnt seal correctly but after draining the oil....it is pretty white. Doesnt really explain how it got into the water passages and my radiator. I can see on the heads where it has surface rusted at the rear and appears to be leaking into the lifter valley.
I am praying that there isnt a crack in the block. Be gentle 'cause I'm having a bad day.
Dennis
Will the Performer RPM fit under stock hood or will I run into problems later when the body is back on?
Good luck
I think the leak actually may be on the head gasket. See pictures below. This looks like the culprit doesnt it?
But why did it happen? Incorrect gasket, incorrect torque sequence/amount, or are the head bolts bottoming out or incorrect length. Just for the hecht of it, lay a straight edge on them.
Dennis
I'll lay a straight edge on it when I take the head off tomorrow.
The hood hit the edge of the 14" air cleaner with a 1 1/8" air filter. I had to sell the Edelbrock carb and replace it with a Holley. I had to grind down the top of the Holley and cut the bottom of the 6" air cleaner. It really looked 'tacky'.
I replaced it with an Edelbrock 2101 and now the 14" air cleaner works with a 1 1/8" filter.
I believe the Edelbrock website states that a Performer RPM will not work on a midyear Vette.
Just my .02.
The note says that later model water necks wont fit because of clearance? Any one have an issue with using the original thermostat housing?
Glad I found this thread. I'm making plans for a new engine for my '63 driver. I'm looking to use a 350 Vortec with the GM #12366573 intake manifold and an Edelbrock carb. I figured if I tried to mimic the 327/340hp engine, hood clearance shouldn't be a problem.
How does the intake compare in height (at the carb pad) with something like an original 327/340hp intake? My car is currently 327/250hp, so the performance upgrade would be quite nice.
mikeyandem1 says an RPM air-gap fits, but cares says Performer RPM will not fit. Is it a problem a with drop-base air cleaner? 1 1/8" filter doesn't sound very big to be causing hood clearance problems.
Thanks in advance,
-Dave
