54 door interior question
Old Mar 15, 2009 | 10:26 AM
MasterDave's Avatar
MasterDave
Moderator
Default 54 door interior question
I was pulling the old vinyl off my door panels. Just above the door pulls are the long decorative covers with (2) notches for the window and latch *****. One of mine is fiberglas and the other is a stamped metal one with formed black foam glued to it to bring it to the same shape as the fiberglas one. I find the wierdest stuff sometimes. Which is correct?
Old Mar 15, 2009 | 11:35 AM
1955 copper's Avatar
1955 copper
2015 C1 of Year
Metal rubber one is early ,fiberglass is second design, few judges check or know the differeance
Same goes for the dash trim as seen here METAL early , later fiberglass , few owners know this, you just have one of each, check your dash trim to see if it's soft, if yes it's steel and (rubber)
Old Mar 15, 2009 | 04:34 PM
Mike Terry's Avatar
Mike Terry
Mine were fiberglass but my 54 Vette was a very late car.
Old Mar 15, 2009 | 09:28 PM
MasterDave's Avatar
MasterDave
Moderator
Thanks guys. I have two dash pieces and they are both fiberglas. I'll hunt up a fiberglas piece, I believe it's the drivers side. Or trade someone if they want the metal/foam piece.
Old Mar 16, 2009 | 12:21 PM
1954corvair's Avatar
1954corvair
Default Early
Roy,
When you say it's early, wasn't it made in the middle of the 54 run. Somewhere between cars serial # 2900-3900? Just asking, I have not a one on my cars and the 55 cars have white fiberglass. The 53's are cloth on mine and crude.
Old Mar 16, 2009 | 12:35 PM
1955 copper
2015 C1 of Year
Originally Posted by 1954corvair
Roy,
Your talking body glass ,I'm talking the crush trim (dash & doors) I don't think anyone know when the change took place <I don't.
Old Mar 16, 2009 | 12:40 PM
1955 copper
2015 C1 of Year
Can you post a pic of the door metal part so people can see the differance
Old Mar 16, 2009 | 04:28 PM
MasterDave's Avatar
MasterDave
Moderator
Later this afternoon Roy. I hate working, it cuts into my hobby!
Old Mar 16, 2009 | 07:05 PM
MasterDave's Avatar
MasterDave
Moderator
OK, here's the two different pics of the door pieces. One metal/rubber and one fiberglas.
http://i33.photobucket.com/albums/d6...doorparts1.jpg
http://i33.photobucket.com/albums/d6...doorparts3.jpg
Old Mar 16, 2009 | 07:33 PM
1955 copper
2015 C1 of Year
You will notice that the steel one also was covered with a cotton material glued to the rubber to increase the thickness . All 53 and early 54 had them.
Old Mar 16, 2009 | 08:22 PM
MasterDave's Avatar
MasterDave
Moderator
Yes, this one has a darker woven materiel glued to the foam. What looks like rust from the outside is actually the foam /cotten materiel which has pulled away from the metal a bit. Did not know this, Roy is a wealth of information. Very interesting, thanks Roy.
To 54 door interior question
