heat riser
Old Mar 16, 2009 | 05:43 PM
schawg's Avatar
schawg
Default heat riser
should I remove the heat riser from the exhaust? I have installed a holley 600 with electric choke on my 65sb
Old Mar 16, 2009 | 05:58 PM
bmcnitt's Avatar
bmcnitt
I don't think it makes any difference does it? The riser will still stay closed until the car warms up and stay open once it does.
Old Mar 16, 2009 | 06:21 PM
Powershift's Avatar
Powershift
If you live in a southern climate, it would probably be a good idea. If you live in Vermont or Maine, I would leave as is.
You can remove the butterfly and shaft and weld up the ends, or buy a fuel injected car exhaust spacer that fits in place of the heat riser. Paragon (and others) sell them.
I have done this on many of my cars when living in south Texas and Louisiana. Then used an electric choke (like you) or a manual choke.
If you maintain the heat riser correctly, leaving it in is not a big power loss or engine cooling/fuel issue. Especially in most parts of the country.
Larry
Old Mar 16, 2009 | 07:53 PM
JohnZ's Avatar
JohnZ
You have to have either the heat riser valve or a fuelie spacer in that joint, or the exhaust pipe joint won't seal; the R.H. manifold outlet surface is flat, and the top of the heat riser or spacer is also flat, and uses a gasket with a steel ring to seal. The bottom of the heat riser or spacer is chamfered, to accept the angled sealing surface on the "donut" that seals to the exhaust pipe inlet.
Old Mar 16, 2009 | 08:50 PM
MikeM's Avatar
MikeM
And even if you did find some way to pull the pipe up and make it seal, it's now too short to the engine and will probably ground out on the frame somewhere and rattle.
This has been an issue before here on this forum, believe it or not!
Old Mar 16, 2009 | 08:52 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Just wire the riser open with some stainless steel wire. I used aircraft safety wire that I've had laying around for years...
To heat riser
