Ignition shield liner
Old Mar 19, 2009 | 10:35 PM
69 Yenko's Avatar
69 Yenko
Default Ignition shield liner
Has anyone ever experienced an intermittent ignition problem because their IGNITION SHIELD LINER was missing? My liner on the top cover is missing and once in a while I have an intermittent misfire. I have new wires, cap, rotor, etc. By the way, this is on a 1966 427/390 car with stock shielding. As I indicated, the problem is intermittent. when I removed the top cover and drove the car it seemed fine. But the problem may or may not show itself at any given time.
Old Mar 19, 2009 | 10:47 PM
Bill Irwin's Avatar
Bill Irwin
It's quite a possibility, it was on there for a reason. Suspect you're getting a little leakage from the plug wires to the uninsulated sheild. Bill.
Old Mar 19, 2009 | 11:03 PM
69 Yenko's Avatar
69 Yenko
My thoughts exactly Bill. I am just wondering if anyone else has experienced the problem. Thanks for your reply.
Old Mar 20, 2009 | 11:16 AM
gscott's Avatar
gscott
My 66 427/390 with TI works fine without it, I purchased the liner but haven't been able find what material I need to attach it with.
Gary
Old Mar 20, 2009 | 03:02 PM
Bill Irwin's Avatar
Bill Irwin
Gary, can't speak for the BB, but my SB used 2 plastic or nylon rivets. Bill.
Old Mar 20, 2009 | 03:31 PM
Ron Miller's Avatar
Ron Miller
Yep, sure have!! But mine wasn't intermittent, showed up after I had run my car for a short time without the SS ignition shield installed. When I put it back on, wouldn't start. Removed the cover, started fine. Then I found the inner cover was gone, a burned spot where current was leaking to the cover. A new liner and two plastic rivets from LIC cured the problem.
Correctomundo!! The liner is there for a purpose!!
Old Mar 20, 2009 | 04:27 PM
rgs's Avatar
rgs
My liner was in place, but had a burnt spot where it had been arched through. Same problem as others noted, misfire when the top cover was on, fine with it off.
Old Mar 20, 2009 | 06:40 PM
69 Yenko's Avatar
69 Yenko
Thanks Ron,
As I thought, it is there for a reason. Going to order it and install and we will see. Some say to use nylon rivets to install, I don't see how that works, no holes. I guess just use silicone?
Old Mar 20, 2009 | 07:47 PM
Ron Miller's Avatar
Ron Miller
Thanks Ron,
Mine had a couple of small holes in the top of the shield for the small rivets. When I got into doing mine, I also found out there were several (maybe 5 or 6) variations of the mid-year ignition shield, don't remember what the exact differences were, but I'd check LIC catalog to see if they may list them. I believe that's where I wound up ordering my liner from.
There may have been a thread here as well, you might try doing a search (if it works ), should be 6 months to a year ago as I recall.
Edit: Here's a link to LIC's page, I don't see offhand where there was an ignition shield without the holes, although they do show some differences. http://www.licorvette.com/pdfcatalogfiles/cat/30.pdf Maybe someone with a little more knowledge will choose to share it with us!!
Old Mar 22, 2009 | 11:35 AM
69 Yenko's Avatar
69 Yenko
Thanks again Ron. I used your LIC link to look at the big block top cover and it doesn't show any holes. My car is a 390 HP car, so that is correct.
Yesterday was a beautifully day here in SW Florida so I took the car our without the cover again and no misfires, and it ran great. I will use clear silicone and fasten to see if my intermittent problem is solved.
Thanks for your help.
Old Mar 22, 2009 | 12:12 PM
Ron Miller's Avatar
Ron Miller
OOPPS!! Sorry about giving you the incorrect link, although I see you've overcome my misdirection! I didn't realize yours was a big block, mine are all small blocks and I gave you the small block page.
Glad you're able to find out about your particular situation!!
Old Mar 22, 2009 | 01:44 PM
narlee's Avatar
narlee
I think some of the variances were the # of rivets and what they were made of. I think early ones were metal and then they changed to nylon.
Old Mar 22, 2009 | 01:50 PM
Ron Miller's Avatar
Ron Miller
That's right, but again it applies to small blocks. He's got a big block, they didn't use any rivets.
To Ignition shield liner
