AC pump ?
Old Mar 20, 2009 | 12:44 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Default AC pump ?
I'm getting set to run the new engine in the test stand this weekend and I need a question answered.
The engine has a serpentine drive with AC pump and I'm wondering if it will hurt the pump running it out of an AC system. It's a hassle getting it out of the loop and I'd rather not if I don't have to.
Any help appreciated.
Dave
Old Mar 20, 2009 | 01:21 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i wouldn't... while there is oil in the pump body, the lubrication of the pump is done by the freon and oil circulating when the system is running. AND you run the risk of dirt and moisture getting into the pump.
Bill
Old Mar 20, 2009 | 01:29 PM
67-427ci's Avatar
67-427ci
As long as you don't engage the pump clutch you should be OK. Only the pulley will be turning.
Roy
Old Mar 20, 2009 | 01:33 PM
claysmoker's Avatar
claysmoker
Bill
I would plug the holes with some tube to prevent the contamination issue.
Old Mar 20, 2009 | 01:34 PM
claysmoker's Avatar
claysmoker
Roy
I wondered about that. No power to it and it should freewheel, but I'll check to make sure.
Thanks for the help
To AC pump ?
