1959 tach question
Old Mar 22, 2009 | 03:59 PM
Treetopflyer's Avatar
Treetopflyer
Default 1959 tach question
The tach on my 59 goes to 7000 and red lines at 5000. I have been told that the tach drives on the generators were geared for specific tach gauges. My question is, do I need a specific mechanical drive on the generator for my tach gauge or will all 1959 Corvette generators work? Currently the tach gauge is not hooked up since I have a standard Delco generator that is lacking the shaft for the drive. I have found a generator, but before I buy it I want to make sure I am purchasing the right mechanical drive.
Old Mar 22, 2009 | 04:04 PM
62Jeff's Avatar
62Jeff
Hmmm, I've never heard of that.
However it IS true that tachometers that were driven off the distributor (all 62's, and pre-62 Fuelies) have a different drive ratio than generator-driven tachs.
I'll be curious to see if anyone can substantiate what you've been told.
Jeff
Old Mar 22, 2009 | 04:10 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Corvette Central lists the same drive and gears for '55 through '61 if that is what you are asking:
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000050e~Z5 Z5Z5AAPCT~P129.95~~~~S2M00YL697242331107 35a~Z5Z5Z5~Z5Z5Z50000050x
Since this one kit works for all of those years and has a single gearing mechanism I would assume any generator from those years would drive the tach correctly and at the right ratio.
Old Mar 22, 2009 | 04:12 PM
JohnZ's Avatar
JohnZ
All the tach-drive generator gearboxes were the same - they were all 2:1 reduction (50%), so the cable ran at crankshaft rpm, assuming you have the correct crank and generator pulley diameters.
Old Mar 22, 2009 | 06:50 PM
Ironcross's Avatar
Ironcross
I believe the power steering generator from the passenger cars is also the same with the same cable drive out of the rear housing.
Old Mar 22, 2009 | 07:57 PM
1snake's Avatar
1snake
The only difference was with the tach. If generator driven, it registered cable speed, if distributor driven, it registered twice the cable speed.
Jim
Old Mar 23, 2009 | 06:31 AM
Treetopflyer
Default Thank you
Thank you all for the info. I appreciate it. I feel more comfortable buying this generator.
To 1959 tach question
