c1 soft top trouble
Old Mar 24, 2009 | 11:13 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Default c1 soft top trouble
My 62 fawm/fawn came with hardtop only and I retrofitted a correct soft top. The side rails sag a little with the top up. Everything I've read says there's some kind of lock mech. but no evidence on mine. Any ideas,photos,numbers,etc. thanks,RK.
Old Mar 24, 2009 | 11:34 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
no lock that i know of
Bill
Old Mar 24, 2009 | 11:39 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Not on my soft top....on my old conv Mustangs tho there were some adjustments to get the side rails over the roll up windows horizontal; there were also some kind of thin steel cable to maintain tension IIRC...
Old Mar 24, 2009 | 12:50 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
The "locking mechanism" you are referring to is probably located on the the frame mounting brackets mounted on the large triangular shaped metal support behind the seats. Try loosening the bolts on the inner bracket and then have someone lift up on the center of the side rail (where the joint is located) while you tighten the bolts.
Charles
Old Mar 24, 2009 | 04:58 PM
drivette's Avatar
drivette
Default I agree,.... sorta
Charles
This is the correct way to do it! If you don't have a "helper" you can lift the side rail, with your back, while tightening your bolts. However if you installed the top with the frame not adjusted completly, you may be SOL. Lar
Old Mar 24, 2009 | 05:41 PM
Fawndeuce's Avatar
Fawndeuce
One of your side rails may also be bent, use a straight edge to check it.
Mine sags a bit on the driver's side, but is fine on the pass side. I'm going to try adjusting since I have the seats out anyway.
Paul
Old Mar 24, 2009 | 06:56 PM
56Heap's Avatar
56Heap
I believe the ST-12 outlines the adjustment to get the sag out
Old Mar 24, 2009 | 10:46 PM
62Jeff's Avatar
62Jeff
Welcome!
Where did you get your top frame? I've heard mixed things about the repros, was wondering if you used a repro and if so, if you had any fitment issues.
My 62 has an original top, and there's nothing I'd call a lock associated with the top side rails, unless it's where Charles is referring down where the frame mounts to the car.
Thanks!
Jeff
Old Mar 24, 2009 | 11:36 PM
Fawndeuce's Avatar
Fawndeuce
Yes welcome! My appologies for not noticing that you were new to the forum. I sent you an answer to your PM, hopefully we'll get the cars together this summer.
Post a pic, we love pics on this forum!
Paul
To c1 soft top trouble
