I believe I am going to pull the 3 speed out of my 54 and put back in a powerglide.
Is there a difference in a powerglide that was in a 53-55 vette vs a passenger car? The car does not have the original block, so at this point I do not mind putting in a tranny that works without breaking the bank. Are the linkage hook ups the same? I can buy the 54 shifter set up just need to know what year powerglides it will bolt up to.
Any help is greatly appreciated. I have searched but have not come up with these answers.
Altho I don't claim to be a PowerGlide expert, I am aware of some of the differences:
In '53 and '54, passenger cars used an enclosed driveshaft while the Corvette used an open drive shaft. The transmissions for these cars differed in the tail shaft housing needed to adapt to the two styles of drive shaft.
'55 and later PowerGlides have some design changes compared to the '53/'54 transmissions. As an example, the '55 and later PG units use modern and readily available speedometer gears with a wide range of tooth counts. Not so with '53/'54 PG units; speedo gears for these are difficult to find. You'd probably want to get the later transmission.
No matter what year PowerGlide you get, you have to look specifically for one that has a rear housing with the boss for rear transmission mount.
I run a passenger 'Glide in my '55. The tail shaft, converter are different but work in my car. Linkage on a 6 cylinder is different, if your trans came from a 6 that might save you some time scrounging a few parts. Drive shaft may have to be altered. It bolted up to trans mount fine with the cast mounting bracket repro part I bought.
Reason: add comment
Good luck,
Jim
53 to 55 dint have a rear trans boss for the shifter ,the shifter was mounted to the body.
Original Corvette powerglide stuff is expensive, but you can cobble together enough passenger car parts from 55 and later powerglide cars to make it work right. Won't be original, but it will work fine.
Start looking at 55 / 56 6 cylinder powerglide cars. Most of the parts you need should be there.
As stated before, you may need to modify the driveshaft. If you have your original driveshaft, I suggest not cutting it up. Just have a replacement made.
I think he is talking about the transmission mount, not the shifter mount. There is a separate bracket that bolts to the rear tail housing that provides the transmission cross member mount. They are available repo for about 50-60 bucks.
This is the way Chevrolet mounted powerglides in early C1s (through 57, I believe).
Will the linkage from a 53-54 original shifter hook up no problems?
I got my "patch" from Bart in San Jose CA, I think company was something like: 5362 Corvette. Maybe others may remember his contact info.His part saved me a lot of hassles. Eatondolittle@wmconnect.com
Reason: add text
I was able to use neutral safety switch from Corvette Central with no problem.Used relay [3 prong] out of Nomad at a fraction of 'Vette relay. Works fine.
To bad my powerglide I just had pulled out of my 65 yesterday won't work. I had a th350 put in, so it's looking for a good home. The powerglide, I mean.
What about the assorted linkage? Where did you get that? Did it all come from Corvette Central? The big issue is the transmission gear selector lever. You need one that has the tab and small hole in it to engage the neutral safety switch.
I fabricated the tab with the hole of a diagram in Noland's book. It is an obvious fabricated part,but my car is a driver. Kick down linkage was cheaper from classicchevy.com same parts...
