Need help with decoding options on 66 Conv.
I know it was built March 1966 by the Vin# and it was a St. louis car but thats about it. It does have a Saddle interior dash and I think it may have been Nassau Blue as the underside of the decklid matches that color. How do you know what the original motor was? Options like knock offs,hub caps,STD or leather, ETC and all that stuff?
I was able to get some history on his other 66 conv race car that has been sitting in his heated garage for 19 years and is solid. I want to get that car back on the road so my dad can enjoy it again before his time is up. That one did have all the body/vin plates so I was able to see it was built in Sept 65 in St. Louis too. Original Mossport Green
(982AA). Has original hardtop and conv. top frame and big block hood. I wood also like to decode this thing too with the other options. Gas tank has been swapped years ago on both cars and motors are currently small block 327/300 HP.
The previous owners had raced them both back in the 70's-80's with a 427 in one but doubt that was an original. I'm not that lucky.
If anybody can help me or tell where to go It would really help. My father had cancer but is clear right now so I would like to give him the pleasure of cruising his old cars again and not letting them rott and ruin the history of the greatest american sportscar.
You can PM or email me with any info.
Aaron
rasrboy@hotmail.com
There are no records of what options those cars had. All you can do is look for clues based on what you find on the car. What redline does the tach have, do you believe the tach is original to the car?
What throttle brackets does it have? Sometimes those can limit the car's possible options to a few.
Etc. etc.
A good place to start is with the tach. If it it 6500 redline it would have come originally with a high performance motor. A low perf motor would have a 5500 rpm redline.
The pad on the block is potentially the single most important clue you will have. It is on the passenger side top of the block just forward of the front of the cylinder head and will hopefully have two number stamped into it, one should have the partial VIN #, and the other number should have letters and numbers. Check this out and post a picture, or the numbers.
Let's start there, as far as option go, it is very difficult, sometimes impossible to tell the way a car was originally configured. Mopars, Mustangs, Pontiacs, even other Chev's have resources for this stuff. For the most part, Corvettes do not.
Aaron
rasrboy@hotmail.com
Yes the other car took a hit at Painesville speedway in the mid 80's and the front end was glassed over by Stafford and repaired half A$$. It will get a new front clip with working headlights and everthing will be done right including checking the frame. It will get painted the original Mossport Green and be a nice cruiser car.
BTW, You could speak a little more professional here on the open forum
as well as being respectfull!
Aaron Quine
Aaron
rasrboy@hotmail.com
Pancho is a friend and was a member of our club. He is a great source for more info when I tear into it.He really knows his stuff and he was on my list of people to call. Thanks for the info everyone.
Aaron
Aaron Quine
