Mini Hi torque starter
Old Mar 30, 2009 | 09:26 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Mini Hi torque starter
Anyone have any experience with the mini high torque starters? Any recommendations?
Thanks,
Rex
Old Mar 30, 2009 | 09:33 PM
Donny Brass's Avatar
Donny Brass
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
I love my genuine GM high performance one.......
turns over my 12:1 small block every time........
Old Mar 30, 2009 | 09:38 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
My son uses one in his 700HP NA '67 Camaro... no problems
Old Mar 30, 2009 | 09:40 PM
Dr L-88's Avatar
Dr L-88
Forgot to mention................I need one with the same terminals on the solenoid as a stock starter...................4 terminals.
Old Mar 30, 2009 | 09:42 PM
OCS1667's Avatar
OCS1667
I never even thought about the old starter when I put my car togeather. I installed the new high torque starter and have never looked back. It kicks the engine over on the hottest days with out a problem.
Dennis
Old Mar 30, 2009 | 10:18 PM
schawg's Avatar
schawg
Default powermaster w/nosecone
Old Mar 30, 2009 | 10:20 PM
Donny Brass
my car starts fine with the run wire missing.............
Old Mar 30, 2009 | 10:25 PM
63Corvette's Avatar
63Corvette
I have run a Tilton race starter since 1984 without problem.
Old Mar 31, 2009 | 09:06 AM
jim lockwood's Avatar
jim lockwood
Rex,
I don't know of a mini-starter that includes the terminal for bypassing the ballast resistor. I guess the sellers of these starters assume you are going to use electronic ignition instead of points.
If you need the ballast bypass function for a points ignition, you would need to incorporate a separate relay (triggered off the starting circuit) for this purpose.
Good luck,
Jim
Old Mar 31, 2009 | 10:05 AM
65 fi's Avatar
65 fi
Just bought one for a 70 454 Chevelle we have. It seems to work great and so much lighter and easier to fit into place. I found a big variation in pricing. In the end I picked up one with the same bolt pattern and terminals for $120.00. It's a clone of the G.M. (but not Chinese). It seems that the G.M. is not made by G.M. anyway.
Old Mar 31, 2009 | 10:10 AM
Dr L-88's Avatar
Dr L-88
Can you give me more details?
Thanks,
Rex
Old Mar 31, 2009 | 11:16 AM
Russ T Gate's Avatar
Russ T Gate
Rex, I use Summit's mini on my 502 and it's worked great for over 5 yrs now. Part # is SUM-820323-OS price $195.00. this starter has a staggered mount so you can position the starter away from headers or the block. It does not have the 4 wire hookup.
Good luck.
Russ
Old Mar 31, 2009 | 01:19 PM
narlee's Avatar
narlee
You can always run it without the bypass.
Old Mar 31, 2009 | 03:21 PM
avideo's Avatar
avideo
Default I Have a Powermaster XS that I installed last summer...
on our 1966 small block. Works great even on the hottest days and clears the headers with lots of room to spare.
Old Mar 31, 2009 | 04:44 PM
schawg's Avatar
schawg
the powermaster has the R and S terminals. I just installed one on my 65sb 3wks ago. Works great! www.powermaster.com.
Or just google powermaster starters give them a call their techs are very knowledgable.
Old Apr 1, 2009 | 08:38 AM
jim lockwood
double check your link to power master. it takes me to a page full of Korean characters and a picture of a NASA astronaut.
Old Apr 1, 2009 | 09:37 AM
Shurshot's Avatar
Shurshot
Hmmmm ....... my old one has three terminals rather than 4.
However on this re-build it is going to be retired to the shelf. Besides being big and heavy it will not go into place with the headers already in place........ but I can't put the headers on or take them off with the starter in place
At 58 and laying on my back that old starter is to much work. Think I am going to try the one from Summit this time around.
Doug
To Mini Hi torque starter
Old Apr 1, 2009 | 11:43 AM
schawg's Avatar
schawg
www.powermastermotorsports.com
Old Apr 1, 2009 | 12:15 PM
Tonytz06's Avatar
Tonytz06
I have had two GM units on my 572 crate motor and nothing but problems. Starts but like it's a hot start, draging. Switched to a Hitachi from Kragens.
Old Apr 2, 2009 | 03:12 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
George
