calibrating temp gauge
Old Apr 20, 2009 | 08:11 PM
Larsonfamily's Avatar
Larsonfamily
Default calibrating temp gauge
I'm interested in validating the temperature gauge - can anyone tell me how to test the calibration of the temperature sensor ("stock") and the stock temperature gauge in the dash. I've got a stock small block in a '63. I'm looking for voltage amount (?) coming to gauge from the bi-metal sensor at different temperatures. I'm assuming that I'll have to put the sensor in a pan of water with a reliable thermometer, 12 volt source and a meter.
thanks for any help
Mark
Old Apr 20, 2009 | 10:04 PM
buns's Avatar
buns
Much info here: http://www.lbfun.com/warehouse/tech_...eCF-Thread.pdf
Old Apr 21, 2009 | 09:26 PM
Larsonfamily
great info. thanks. Another dumb question - OK - I've got a particular sensor and I confirm heat and ohms relationship with my handheld meter. Now, suppose the temp gauge in the dash doesn't reflect the right temperature - is this fixable? The article you pointed me to talks about adding a resister, but the negative of that was that all other points on the temperature reading curve were wrong. Doesn't sound like much of a solution. Must be a better one, or I didn't understand. What am I missing?
thanks again to all,
To calibrating temp gauge
