fixing rotor runout
Old Apr 23, 2009 | 07:49 PM
turbocat's Avatar
turbocat
Default fixing rotor runout
since installing new trailing arms ,I have been having the dreaded "low peddle " because of rotor runout. I took my 66 to the alignment shop and they said they could turn the rotors on the car to fix the runout problem. They called later and said they couldn't do the rears , only the fronts. Called another shop and they said the same thing. They said the only way to fix the runout was to get tapered shims from Chevrolet. Is this the only way? Does anyone know where I can get my rotors turned on the car? Would these shims be as good as turning the rotors?
Old Apr 23, 2009 | 07:59 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
I'm pretty sure NAPA has tapered shims.
Because I'm cheap, I fixed a slight runout problem on two of my rotors with an aluminum beer can, a pair of scissors, and a hole punch.
Old Apr 23, 2009 | 08:20 PM
LB66383's Avatar
LB66383
I doubt, because of the suspension design, that you'll find anyone who can turn them on the car. I'm assuming the rivets have been drilled and the rotors can be removed easily. Make sure the rotor and hub mounting surface is clean and you don't have crud between the two causing excessive runout. Use a dial indicator to find out how much runout the rotor has. Then try removing the rotor and remounting it on the hub one stud clockwise from where it was and remeasure. Repeat. You may find one position where the runout is below spec. If not, find the position where it is the least, and shim it there.
Old Apr 23, 2009 | 08:38 PM
turbocat's Avatar
turbocat
From the replies that I am getting, it looks like shimming is the acceptable method to repair the runout. Thanks for the information.
Old Apr 23, 2009 | 09:06 PM
Avispa's Avatar
Avispa
You can also have a machine shop grind the rotors while they're attached to the spindles. The runout will be zero. The whole dreaded runout thing is because the factory made the rotor/spindle assemblies that way.
Old Apr 23, 2009 | 10:14 PM
buns's Avatar
buns
You may be able to find shim stock at your local auto supply. A company called H.Paulin (a.k.a. Papco) sells a variety pack.
Old Apr 23, 2009 | 10:56 PM
turbocat's Avatar
turbocat
This looks to be cheaper than the napa tapered shims, but I like the idea of tapered shims giving a more even surface under the rotors.
Old Apr 23, 2009 | 11:12 PM
daytonablue64's Avatar
daytonablue64
I found an assortment pack of round arbor shims at Grainger. They come in various thicknesses starting at 0.001" and up. I think the pack cost around $14.00 with shipping.
Came with large enough assortment to do all 4 rotors.
I also tapped the rivet holes and counter sunk tappered head bolts to hold the rotors in place. Dialed runout to aprox 0.002" each.
Old Apr 24, 2009 | 10:53 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Runout
I agree with all of the above. If you are in the upper ranges of acceptable runout and you still have air in your brake system, it may be time for O-ring pistons. They are more forgiving than the factory pistons. Jerry
Old Apr 24, 2009 | 11:22 AM
MikeM's Avatar
MikeM
I don't think rotor runout will give you just a low pedal. Maybe a "soft, spongy" pedal that picks up pressure close to the floor. There is likely a difference in the cause of the two problems.
Old Apr 24, 2009 | 12:41 PM
ptwohey's Avatar
ptwohey
I did like nassau66427 and used an aluminum can but think that "things go better with Coke" and besides that, the beer cans had a deposit on them.
I also did like LB66383 and rotated the rotors for the least amount of runout before shimming.
If you are not replacing the rivets with bolts, remember to put the lug nuts on and don't attempt to measure runout without the rotor bolted firm. Also check your hub/bearing end play to make sure that is not adding to the problem.
Old Apr 24, 2009 | 12:51 PM
turbocat's Avatar
turbocat
I'm pretty sure it's a runout problem. I can drive the car for 500 miles and the peddle gets softer and lower .There is no loss of brake fluid in the master cylinder and just a small amount of air comes out of the lines after bleeding, then the brakes are good for another 500 miles or so.
Old Apr 24, 2009 | 01:26 PM
turbocat's Avatar
turbocat
Well-I called Napa and the shims were $21.00 a piece and $15.00 SHIPPING!! At that rate I can see $200 or more to do the shimming. Looks like I'll try the arbor shims!
Old Apr 24, 2009 | 03:15 PM
JohnZ's Avatar
JohnZ
One of our local shops has an on-car rotor surfacer that works fine on Corvette rears - all they have to do is to unbolt the half-shaft from the spindle.
Old Apr 24, 2009 | 06:17 PM
MikeM's Avatar
MikeM
Since you have a soft pedal, that might be your problem. I'd try the shims before i'd have the rotors cut.
Old Apr 24, 2009 | 09:02 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
After reading the postings in this thread, I'm liking the trouble-free drum brakes on my '63 roadster better and better.
Jim
Old Apr 25, 2009 | 08:29 AM
MikeM's Avatar
MikeM
Jim
Me too!
To fixing rotor runout
Old Apr 25, 2009 | 10:08 AM
Mike Ward's Avatar
Mike Ward
Jim
The ironic part of the rotor run-out issue is that it is a self induced problem in 99% of cases. For all sorts of reasons people 'feel the need' to swap rotors when there's actually nothing wrong with their existing ones.
Another case of fixing something that's just not broken.
Old Apr 25, 2009 | 10:30 AM
turbocat's Avatar
turbocat
So what you are saying is my old rotors should have worked fine on my new trailing arms even with the badly bent spindles that I had?
Old Apr 25, 2009 | 10:36 AM
landshark 454's Avatar
landshark 454
Your problem is not a warped or wobbling rotor. Niether will cause air to enter the system. A loose wheel bearing, will cause a low pedal, with no pulsation in the pedal. A warped or wobbling rotor can cause a low pedal, with a pulsation. However, with either of these problems, if you apply the brakes, when standing still, the pedal will be low on the first application, but a second application will result in a firm, good, pedal. This is because the loose or warped rotor pushes the pads away from the disk, nothing else. The first pedal push puts the pads back against the rotor, then by the second push, the pads are in proper place, so the pedal feels fine. Low pedal or high, the pedal will be firm, once the travel is taken up and the pads contact the rotor. There will be no soft pedal. Soft means air is in the system. Since you are not loosing fluid, and getting a small amount of air when bleeding, air is entering through a bad caliper. I have seen this problem before. I have also seen this on my vette.
Next time you bleed, any calliper that releases air is a bad calliper, and should be changed. Rich
