Birdcage Advice Needed
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG]Brand new frame, 383 motor, tremec 5 speed, rebuilt t-arms and diff. I took off the rear quarters and front end because they were flaired and the buckets were filled in.
Any advice is greatly appreciated. Thanks.
Your number 3 mounts are about like mine were, I think fabricated sleeves are the way to go for that part.
If you need a hand, give me a call.
Pilot Dan
Pilot DanR/Jeff
Thanks.
Thanks,
Pilot Dan
And thanks everyone else for the feedback and encouragement.
Eddie
[IMG]
[/IMG]It would be great to find some history on it. But I doubt that will happen.
Anything else is just a patchup job IMO.
Mine didn't have rust in the lower area like yours, but riddled in the lower windscreen area, rear dock lock area, and even under the bonding strips in the front area of the roof area;- and yet that looked fine before I pulled it all apart.
Yep, it's a pain in the #*rse to do, but the ONLY way to do it, regardless of what anybody eles is telling you.
It's a frightening thought, but let's be honest, these cars are getting old, and unless they've spent their entire life undercover and on the West Coast, most will have varying degrees of rot problems in the birdcage area. I guess if you don't see them, you don't worry about them, but they are there.
I knew mine was bad, but I was shocked when I got into it, and the car was purchased as supposedly a West Coast car:- well it might have been in its later years.
It's about time some enterprising company started building replica birdcages I think.
Good luck with your project.
