Tail Light out need help
Old Apr 25, 2009 | 10:21 PM
splidecision63's Avatar
splidecision63
Default Tail Light out need help
Hello Yall,
Need some advice on why my tail lights, brake lights and turn signals do not operate. Is there something common to all the ablove. It must be a ground problem, but where do I look? Please PM, I get lost looking for something on this site.
Thanks George
Old Apr 25, 2009 | 10:46 PM
Pilot Dan's Avatar
Pilot Dan
Check the connector at the bottom of the steering column (looks like a crescent shape) for the turn signal switch and make sure each of the individual pins in the connector is tight. One loose wire here would produce your symptoms. Pilot Dan
Old Apr 26, 2009 | 01:42 PM
JohnZ's Avatar
JohnZ
The brake lights and turn signals go through the turn signal switch, but the taillights (and license light) don't - they're separate circuits with no connection; most likely you have no ground. There should be a ground for the rear harness at the left rear corner of the trunk.
Old Apr 26, 2009 | 10:09 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
have you checked the fuse?
To Tail Light out need help
